Ball Joints
Old Dec 15, 2004 | 11:11 AM
tf0r1's Avatar
Car: 92 RS 25th Aniv. V8
Engine: 350 L05 TBI
Transmission: 700R4 Raptor
Ball Joints
ok, I'm getting ready to change my springs (front and back) and rpl my shocks and struts...Im gonna rpl my (lower) ball joints (they're wasted)... The venders here in south jersey seem to have either TRW, which come in one size, or perfect circle which come in stock size, and also they offer an oversized more expensive version...Ive never heard of perfect circle parts, and Im leary..But also, Ive heard people slam TRW, and yet rave about Moog (go figure--same company)..Gonna do the big suspension upgrade Friday night after work, so that rules out ordering from the internet, so Im stuck local.. Which in your opinion is the better choice...Also changing my swaybar links, again perfect circle offers 2 types, stock and high performance...But on this, my parts store offers moog, I thought I'd just get the moogs..
Thanks for your input
Old Dec 15, 2004 | 11:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
You won't need the oversized ones, unless for some reason things are mangled, and the stock size won't fit in right.
I would recomend going to Napa, and getting the Napa Chassis line ball-joints. They are a very nice peice.
HTH
Old Dec 15, 2004 | 01:35 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Check the stock numbers for NAPA's lower line and you'll see they match the TRW part numbers. I've had good luck with TRW parts. Good advice from Dewey316.
Old Dec 15, 2004 | 01:55 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I haven't had an issue with TRW or Perfect Circle, and they are decently priced.
Buy Energy Suspension swaybar endlinks
Old Dec 15, 2004 | 04:12 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Actualy I will make this very easy.
https://www.thirdgen.org/techbb2/sho...&highlight=NPC
https://www.thirdgen.org/techbb2/sho...hreadid=197895
Those two threads should cover every front end part.
Old Dec 15, 2004 | 10:10 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I have always stuck with Moog but they are not cheap by any means.....
Old Dec 15, 2004 | 10:24 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Thats the neat thing about that list I posted. The lower line at napa is TRW/Moog (check the part numbers, they are the same). The upper line is even nicer, most of them are Federal Mogul I believe.
Old Dec 16, 2004 | 08:07 AM
tf0r1's Avatar
Engine: 350 L05 TBI
As always thanks Guys...Wish me luck, I cant wait till Friday night too get this all done...Truth be told, Im a lil bit nervous about r&r'ing the front springs, just from a safety perspective..Other than that, I cant wait...Ill let you know how I make out
Old Dec 16, 2004 | 09:06 AM
naf's Avatar
naf
Use a spring compressor when you take them out (you can rent one at autozone) as the spring will still be under some compression when you drop the a-arm down. It also makes it alot easier to reinstall. Make sure you've got them indexed when you put them in.
Old Dec 18, 2004 | 05:35 PM
tf0r1's Avatar
Engine: 350 L05 TBI
Well all the parts are in and WOW what a difference..The worst part was removing the old sway bar links, what a pain that was...It was a bit scary popping out the old front springs, the spring compressor we had was too small for the springs, so we used a pry bar, (after lowering the A arms) but it all worked out...I was shocked how small the moog iroc springs looked when comapred the oem springs, when placed side by side..The Moogs were smaller, like about 2 inches or so and a whole lot meatier than oem, so they were easier to put in because they are shorter.. Anyway, after new springs, shocks,ball joints, swaybar links and an idler arm it rides and handles like or better than it did in 1992 when it was new... All you guys that mention suspension upgrades over/ or before drive train or performance upgrades, Heres to you: (CHEERS! ) !!!!!!
I ended up going with the sensatrack shocks/struts, and honestly, they feel great..This is the second pair I put on..And the first pair was with the OEM springs (saggy) and I think that was the deal breaker..My old sensatracks never, not even on their first day felt this good..Now I blame them old OEM springs for all my evil thoughts towards Sensatracks...Its really sweet to be able to rip through cork screw corners while speeding up, ahhh the old days are back!!!...Now I truely remember why I love this car
I must mention that the old saggy springs looked alot better, the stance was pretty cool looking...Truth be told, Im not use to seeing all that space in the front between the tire and fender, looks like Im in the pop-a-wheely mode... But I think the front will settle down a little in time...Although the new stance is kinda weenie looking, I love the way it drives
Old Dec 18, 2004 | 10:48 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Yeah, new springs and suspension parts make your **** feel like new!!! I would always suggest to anyone to freshen up the suspension before going nuts with engine work.
I know what you mean about the sagging springs giving a nice look. My Z had some old, nasty springs, then when I replaced them with Eibach Pro springs it still raised the frontend slightly. By now it has settled some, but not too much. Close to where it sat before. At least the rearend gap was tightened up alot, looks much better! Coil overs coming next I think!!!
Your springs will settle some, but not that much. Just remember, you can't see the fender gap while you are driving with a hot blonde's head in your lap!!
Old Dec 19, 2004 | 12:04 AM
tf0r1's Avatar
Engine: 350 L05 TBI
How true with one exception... I never had much luck with the blonds or Fords..Nope...All my luck is with the hot little brunetts...You say Potatoe, I say puttato..Its all good....
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
