k-member
Old Dec 28, 2004 | 09:54 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
k-member
how much weight savings do you get going to a tubular k-member? and about how much are they? i saw a cheap one on ebay the other night and it said along with the rack and pinion setup they sell you save a total of 150lbs
Old Dec 28, 2004 | 12:16 PM
slimdawson's Avatar
Car: 1991 RS
Engine: Procharged LT1
Re: k-member
You definately will NOT save 150. I can't remember how much I saved with just the kmember. It was less than 30 lbs though. The stock kmember isn't that heavy believe it or not.
Old Dec 28, 2004 | 05:10 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
What he said...the stocker does not wiegh as much as you`d think. I switched to a tube k member and it did save some wieght but the biggest advantage is the room it creates, the wieght loss is small,(maybe 30 for the K) you`d be better offf relocating the battery to the rear if wieght reduction is what your after. The A-arms are almost as heavy as the k member..the aftermarket ones are are probably 1/4 of the wieght of the stamped arms.
Old Dec 28, 2004 | 05:49 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
i saw that auction and i believe they were referring to a chromoly set-up k-member a-arms manual rack which would mean no more heavy steering box and no more steering pump brackets etc as far as 150 sounds good but id like someone to find out for sure if it really is good for that much i want 2
Old Dec 31, 2004 | 02:50 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
k member
stock 54.5 pa 19.5
a arms
stock 30.0 pa 14.5
another 40 POUNDS i took off in a lightweight aluminum drag brake kit for the front.
33 POUNDS off the back with a drag brake kit and i already had factory iron discs.
:hail:
Old Dec 31, 2004 | 02:57 PM
slimdawson's Avatar
Car: 1991 RS
I just weighed my stock kmember. 45lbs.
If my aftermarket weights 20, I only saved 25 lbs. You definately don't pay for weight savings. The increase in room is almost worth it.
Old Dec 31, 2004 | 07:51 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
25lbs
the room
the looks
do it.
Old Jan 1, 2005 | 04:45 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Figure K member, a-arms, coil over kit, manual rack will prolly be about 80-100 pounds off the front
Kat
Old Jan 1, 2005 | 06:01 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i took off 79 pounds with k member a arms and drag brakes.
looking for another 30 or so when i do the manual rack.
sticking with my stock spring setup.... never liked the coilover idea, plus ive already got drag springs and struts. no sense in buying parts 2 times just to save 10 pounds.
Old Jan 1, 2005 | 06:28 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
stage 20...where did you get your brake setup from and what was the cost of it?
Old Jan 2, 2005 | 12:32 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
aerospace components. www.jegs.com has them. 5 something for the front and 399 for the rears.
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Mdenz3
Sep 17, 2015 08:36 AM
tricky1
Aug 23, 2015 01:17 PM
overdriv
Aug 20, 2015 03:52 PM
NBrehm
Aug 5, 2015 07:57 PM
