My first post- Bolt on or Weld on Subframe connectors?
Old Dec 28, 2004 | 09:19 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
I been reading this site all day and upto page 22 on the this suspension forum. Anyhow, I am wanting to put some subframe connectors on my 82, but I don't know what the better of the two where. I am going to go with Spohn just because Steve seems like a person that will continue to develope things for our 3rd gens unlike every other company that sells out when a new model comes out. I do not have access to a welder, so bolt on would be nicer, but if their is a big difference in the two I'd rather pay someone to weld them.
Thank you in advance for the responses.
Old Dec 28, 2004 | 09:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you can bolt them in, then take them somewhere to be welded up.
Old Dec 28, 2004 | 09:41 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Weld. There is no comparison. The bolts will wallow over time. Welding them distributes the sub frame forces evenly and not entirely on the bolts themselves.
Old Dec 28, 2004 | 09:57 PM
Project's Avatar
Car: 85 Camaro Z28
Can I use bolt on till I get around a welder and weld bolt ons?
Sorry that sounded confusing
Thanks guys this is a big help
Old Dec 28, 2004 | 10:26 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You can, but you cans get them welded in for $50 or less. Some shops will do it for $30.
Old Dec 29, 2004 | 12:59 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
So in short:
bolt them in, drive to mechanic/fabricator/friend, pay him $/beer, get it welded in. Worth the extra little bit of $ to get it welded in.
Old Dec 29, 2004 | 01:51 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Originally posted by Sonix
So in short:
Exactly.
I've been debating on which SFCs to buy for a while now too. I'm going to be getting some before next track season. Bolt-ins seem nice and easy to work with and then get them welded in, but I'm very tempted to buy Spohn's weld-in. I wish his could be bolted in though...it'd make things easier to bolt them in and get them welded, even if I have access to a welder (uncle).
Old Dec 29, 2004 | 02:24 AM
xpndbl3's Avatar
Car: 1984 Z28
i used the jegs bolt in subframes and later had them welded up. worked out well for me.
Old Dec 29, 2004 | 05:19 AM
oil pan 4's Avatar
Car: 89 Firebird
I wish every one would read the old posts like that.
You should weld them.
Old Dec 29, 2004 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Weld.
JamesC
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
