Front end rebuild/brakes/steering box isues
Old Jan 3, 2005 | 03:00 PM
Abubaca's Avatar
Guys, here's the deal: The ENTIRE front end is getting rebuilt. I'm getting the steering box rebuilt, a FE rebuild kit, struts and springs (rear too) top end strut bearings, bushings, and I'm even going with new LS1 brakes. Problem is I can't afford it all at the same time. Do any of you have a logical order in which to do this work? I don't have enough knowledge with this stuff to form a good game plan. I'll be doing most of it from the manual, and common sense.
Just looking for ideas.
PS- I'm having a "shimmy/shake" problem somewhere up front, and if I can find the source, that my dictate what gets done first.
Old Jan 3, 2005 | 09:55 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Do the steering box, idler arm, and steering linkages first, also add a wonderbar if it's not already there. Then get a set of junkyard spindles, and fab the brakes up off-the-car. That way you can take your time and get it all just right, and when it comes time to put them on you can just drop the A-arms, change the ball joints, swap the brakes out spindles-and-all, and put it back together with the new struts/springs.
That way the only thing you take loose twice is the tie-rods at the spindle (although it will require 2 alignments.)
Old Jan 3, 2005 | 11:11 PM
Abubaca's Avatar
Makes sense.
That's the best idea I've heard all day!
Thanks.
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bellez77
Sep 5, 2015 08:39 PM
