Poly Tie Rod Boots Install
Old Jan 5, 2005 | 05:14 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
I just got my Prothane tie rod and ball joint boots and tie rod sleeves from Spohn. There were no instructions in the package since it looks easy enough.
However, do I just put the poly tie rod boots and ball joint boots over the existing rubber one of my new tie rods and ball joints? Or do I have to remove the rubber?
If not, will the poly boots stretch over the rubber boots when I tighten everything down? The Prothane's are slightly smaller in diameter than the rubber.
Also, do I grease the ball joints and tie rods before or after the installation?
I looked at Sphon's pictures of the tie rod sleeves and it looks like the boots are jut put over the rubber ones.
Tie rod boots
Old Jan 5, 2005 | 02:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Remove the old boots, clean the joints up a bit, perhaps grease the inside of the new boots, and put them on and lube.
JamesC
Old Jan 15, 2005 | 05:47 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Cut new rubber boots off?
I guess I cut the new rubber boots off the new tie rods, then install the new poly bushings?
Old Jan 15, 2005 | 11:10 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Yes, that's exactly what James said.
1992rs/ss
16
Jan 28, 2016 09:58 PM
86IROC112
Sep 7, 2015 01:37 PM
theurge
Aug 21, 2015 12:46 PM
NBrehm
Aug 5, 2015 07:57 PM
