how much weight my car lost with out...
Old Jan 8, 2005 | 10:55 PM
steriko's Avatar
Car: 87 trans am
Engine: 357 ci chevy engine
Transmission: th350
my car is a 87 t-tops trans am
all a/c system (blower,heater,compresor,console,ect)
radio system (speakers,radio)
spare tire
electric fan system (now i have fan cluch)
fog light
all engine hardnes
tpi system (i have a aluminum maniford and carb)
700r4 (i have a th350)
radio console
windsheld water tank
iron heads (i have corvette #128 heads)
timechaing (i have gear drive)
how much weight have my car now????
Old Jan 9, 2005 | 12:55 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Go get it weighed. Next time I happen to drive by a weight station on the highway, I'm stopping in.
Old Jan 9, 2005 | 02:13 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
Can you do that? Just pull into one of those truck scale stops on the freeways and weigh your car? Would be kinda funny seeing a camaro in line with a bunch of semi's
Old Jan 9, 2005 | 02:22 PM
WickedTA's Avatar
Car: 85 TA
I have always wondered the same thing
Old Jan 9, 2005 | 03:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As long as they're not busy they might oblige, or you could try making friends at a local trucking company that has its own scale.
Old Jan 11, 2005 | 10:21 PM
steriko's Avatar
Car: 87 trans am
Transmission: th350
i now
but i can go there but right now because i have the engine out of the car
just need a opinion??
Old Jan 12, 2005 | 12:49 PM
Car: 1997 Corvette
Re: how much weight my car lost with out...
all a/c system (blower,heater,compresor,console,ect) 40 lbs
radio system (speakers,radio) 15 lbs
spare tire 40lbs
electric fan system (now i have fan cluch) why would you do this
fog light 5 lbs
all engine hardnes harness? 10-15lbs
tpi system (i have a aluminum maniford and carb) 5 lbs, maybe? plenum/runners are light
700r4 (i have a th350) 70lbs? I don't know how much a th350 weighs
radio console3 lbs since stereo was already removed
windsheld water tank ~1lb (empty)
iron heads (i have corvette #128 heads) no weight change
timechaing (i have gear drive) probably no change
how much weight have my car now???? whatever stock was minus the above stuff
dropped about 200lbs off, not too bad.
Old Jan 14, 2005 | 11:09 PM
steriko's Avatar
Car: 87 trans am
Transmission: th350
a got some specs errors
the heads are aluminum #128 not iron t
he fan cluch came with the car
Old Jan 14, 2005 | 11:34 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Some recycling yards have scales that im sure they will let you use
Old Jan 15, 2005 | 02:10 AM
Car: 1997 Corvette
Drop another 30-35lbs off for the aluminum heads then.
I'd convert to a dual electric fan setup if you can find one in a boneyard. It'll take some drag off the waterpump pulley and not add too much weight.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
