4th Gen wheels what spacers are needed?
Old Jan 19, 2005 | 09:32 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am thinking about putting some 4th gen style wheels (ZO6) on my 3rd gen. What spacers will I need for the front and the rear? Car has 3rd gen rear with disc brakes.
Old Jan 19, 2005 | 08:52 PM
87GTA Runner's Avatar
Car: 87 GTA
2" front and rear will work. I would get them from www.skulte.com
Old Feb 3, 2005 | 06:01 PM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
I just got some off ebay for 80 bucks a pair
Old Feb 3, 2005 | 06:04 PM
KiLLJ0Y
Guest
Posts: n/a
i got mine from Ebay as well.. 2" all around..
Old Feb 3, 2005 | 07:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Search. You have a few options depending on the offset of the wheels. Are the ZO6 factory or aftermarkets? to my knowlegde there are about 5 different offsets for those wheels.
Old Feb 5, 2005 | 12:40 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Do you want 4th gen rims or Z06 rims? I believe the offsets are slightly different. Either way, you should get away with a 2" adapter front and rear.
Old Feb 6, 2005 | 09:39 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey im looking into getting the same wheels off ebay. they bring a 56 mm offset all around is that good or bad?and wat spacer will i need?
Old Feb 7, 2005 | 11:11 PM
Car: 1997 Corvette
Go to www.skulte.com and go to their tech section, there's an article and table showing which spacers are needed for what offsets/backspacings..
Old Feb 8, 2005 | 12:23 AM
spacecase's Avatar
a good link to see what 2" spacers look like is
https://www.thirdgen.org/techbb2/sho...hreadid=195826
Old Feb 8, 2005 | 12:55 AM
daddy33's Avatar
Car: '85 Camaro
1" adapters?
ok i have a quick question. I dont know if i would be screwed or not. I just got the Z06 rims and tires from my uncle and ordered the adapter kit from summit. The only thing is that the adapter kit is 1". The tires on the rear are 295/35/18 and fronts are 265/40/17. Will it still work but its just that i have to do some banging in the tire wall? anyways i already have them on order and if you guys and check the link out below and tell me what you think i would greatly appreciate it. Thanks for your help! Here is the link below
http://store.summitracing.com/defaul...wheel+adapters
Old Feb 8, 2005 | 12:56 AM
daddy33's Avatar
Car: '85 Camaro
sorry the part # for the above is TRD-7070
Old Feb 8, 2005 | 01:46 AM
Car: 1997 Corvette
You *might* be able to get away with just banging the bejesus out of the rear wheel wells, but the fronts won't clear the suspension pieces (struts!)
Old Feb 8, 2005 | 08:33 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
You will need the 2 inch spacers. Its going to be tough even on the back b/c you will have to set the BFH to mass destruction level to get the back to clear. Fronts probably won't as said...
Old Feb 8, 2005 | 04:28 PM
daddy33's Avatar
Car: '85 Camaro
man this sucks, i wanted them on for this weekend, oh well guess ill have to wait and get the right ones. thanks anyways for the input
Old Feb 9, 2005 | 11:43 AM
daddy33's Avatar
Car: '85 Camaro
well i checked out the site and will be getting 2" for the front but as for the rear do you think 1 1/2" will be fine? i got the '02 vette rims which are 265/40/17 (9.5" rim) fronts and 295/35/18 rear (10.5" rim). Or will i be better off with 2" for the rear. I dont want it to stick out really, just but right there flush with the fender. Anyways i'll be posting my order soon so any info will help. thanks
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
