gear box
Old Feb 12, 2005 | 02:45 PM
82knightrider's Avatar
Transmission: TH200C....700R4
gear box
Will a gear box out of a 88 Iroc fit a 82 firebird s/e?thanks
Old Feb 12, 2005 | 03:55 PM
anyone?
Old Feb 15, 2005 | 01:26 PM
what up
Old Feb 15, 2005 | 06:11 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Do you mean gear box as in transmission or as in a steering box? I believe in '82 the pitman arm was different than the '88 models, and I believe the transmission used a different crossmember as well, but someone else will have to chime in and verify.
Old Feb 16, 2005 | 12:36 AM
thanks duron clocker,oh,and im talking about the sterering gear box
Old Feb 16, 2005 | 09:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it will fit. The only potential problem I can think of, is the fittings for the lines; they could be different. If so, you just need the lines and maybe pump (or at least the little fitting that goes into it for the pressure line) off of the newer car, which will all then swap on as a group. You're renewing the lines anyway of course as part of this, so you'd just need to test your new line in your new gear.
AFAIK the Pitman arm is the same in all these cars, regardless of year or engine or whatever. There's not much that could be changed about that, anyway.
junkcltr
Aug 2, 2019 11:12 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
hectre13
Aug 26, 2015 08:17 AM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
