Trouble with noise after SFCs?
Old Feb 15, 2005 | 09:35 AM
RaMaiRGoD69's Avatar
Car: 88 GTA
Has anyone had trouble with interior/exterior rattle and noise after installing Subframe Connectors? Now when I drive around and no1 is in the car it sounds like my door is rattling.... Anybody have this problem?
Old Feb 15, 2005 | 10:13 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If your door is rattling, then the door is the problem. Check the hinges and the latch. Also could be the window guides and shot. Lots of items in the doors to rattle. The reason why you didn't hear them before is that the chassis was flexing, giving you a softer ride. The doors play an important part in the overall strength of the chassis, especially on t-top and convertibles.
Lon
Old Feb 16, 2005 | 08:32 AM
brutalform's Avatar
Maybe there is some areas under the car that the subframe connectors are touching. This can happen expecially with a stock exhaust. Also when I disturbed the rear control arms, an annoying rattle came from the passenger side. I too thought it was a door. Turned out the bushing was not fitting tight in the hole, and some simple persuasion corrected the problem.
Old Feb 17, 2005 | 06:14 AM
Car: 88 GTA
My doors sounded fine before the SFCs and I currently have LTs with a muffelex Y pipe into a flowmaster setup. Any other explanations?
Old Feb 17, 2005 | 06:48 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You are hearing noises now that were masked by louding ones before SFC installation. Or your installer put them on incorrectly.
After my installation (Spohn tube type) the car was tighter and more rattle free then when it was new. (original owners so I knew the difference)
Old Feb 17, 2005 | 06:49 AM
brutalform's Avatar
Well, That would definatley kill the exhaust tapping idea. If it is not a loose bushing in the rear control arm, (as it was in my case), it must be the door area as Lon stated.
Lon brought up a good point, because my passanger window makes a very faint rattle only when the window is halfway down. Maybe its time for a new window guide, as I replace my 38,000 original mile power window motors!
Old Feb 17, 2005 | 07:42 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
I never noticed a problem with my doors until I had SFC installed. A couple months after the install I noticed a lot of noise and rattleing from the doors over bumps and stuff. I have replaced both hinge pins with greasable ones from AndyZ28 and the annoying rattles are GONE.
Old Feb 17, 2005 | 08:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Keep an eye on your Y-pipe a well. it is very common for your y-pipe to bang into your SFC. Some people even just tach them together to keep them still. Sounds like you found your problem with the doors though.
Old Feb 18, 2005 | 07:00 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
RaMaiRGoD69
(Ow...)
Which SFCs did you install? You didn't say which ones and that would help as there are many differences in design.
Ed
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
mrbird
Oct 20, 2015 03:43 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
