Eibach sportlines-do the coils have to settle?
I installed Eibach sportlines on my camaro and the front end sits a heck lot taller up front than the back..I'll post up some pics once it stops raining but do the coils need to settle??All and any info will be greatly appreciated
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
You index them right? there are two holes drilled on the A-arm seats, thats where the end of the coil should be placed. Even so, check the top of the coil to see if it didnt get caught on the lip, if its just that a few slight bumps purposly hit should seat them in.
When I installed the coils,the instructions said to position the end of the coil in between the two holes drilled on the lower control arm...Is that where my problem is??Is the coil suppose to be on the last hole drilled on the control arm??Also ill hve to check and make sure they are seated properly..Thank you for your help
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
according to Eibachs site, the coils do not settle. the height that they are when installed is how they will sit till they wear out.
Car: 1991 Z28
Well the holes are closely placed so if the coil end is anywhere between the two i would say your fine.
Zepher we are talking about the coil possibly binding on the top mount of the K-member. I would say its not very likely that both are binded but you never know.
well it is possible but i know i didnt do that because the rear coils have already been installed and sit perfectly...i'll have to check out the front coils in the next couple of days
Car: '91 TA vert
Engine: turboLSx
Originally posted by PorscheNoSub
i have never had a set or installed any, BUT is it possible that you have the rear springs on the front?
Mine didn't settle much but there is a noticable (to me) difference now after 6 months of them in. I noticed it more around 3 months ago. It was nothing extreme. 1/4" or so in the front. It's got an agressive stand now that I really like.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
I'd seriously doubt it.
Car: '91 TA vert
Engine: turboLSx
I seem to remember mine sayiong "front" and "rear" so the guy would have to completely ignore the fact that they're labelled and the fronts are quite a bit thicker, shorter and not progressive. Meh...
The weather allowed me to take some pics...I think its just me that made me think that the front is a lil higher.When i took the picture,it looks like its dropped in the front lol...Here are the pics..Let me know what ya'll think
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
