Suspension recommendation
Old Mar 14, 2005 | 12:43 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
I need some recommendations for my suspension...i plan on going with dz lowering springs 1.75 rear and front and i cant decide whether to go with monroe, KYB, bilstein...etc for my struts/shocks....the car will end up carrying a 383 stroker motor and th350 tranny and id like a suspension that rides decently with the power it will be throwing around
smoothest possible ride though i do undertand it is a sports car so its not going to be perfect
also quick q my car has a slight lean you can see it in the hatch and hood and all do you guys think once i have the springs and struts replaced it will fix this lean...the car was hit before i got it but i dont believe the frame was bent or i think id know it
thx
Old Mar 15, 2005 | 10:51 AM
Car: 1989 GTA
TTT (whatever that means)
Old Mar 15, 2005 | 11:36 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
TTT = To The Top
In my opinion Bilstein is the best handling non-race shock available, I'd be running them if I didn't race my car.
Old Mar 16, 2005 | 05:04 PM
DM91RS's Avatar
Car: 91 RS
Bill.....do you run the red or yellow Koni's?
DM
Old Mar 16, 2005 | 05:47 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I seconfd the Bilstein suggestion. With the springs you are looking at, your ride will not be smooth no matter what.
Old Mar 16, 2005 | 07:36 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
i've got the Bilstein/eibach combo and i love it. Drives almost like stock down the road but when you put it into a turn man, that thing is glued.
Old Mar 17, 2005 | 11:21 AM
Axoid's Avatar
Car: 92 Camaro RS
DM
I run yellow in front and red in the rear. The reds/specials are softer than the yellow/sports and that worked well for autocrossing with the stock springs.
I may now be a little under dampened with the current setup which has the car set very stiff, but I'm still messing with it.
Old Mar 17, 2005 | 02:20 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
True. With that amount of drop, the ride is not going to be smooth. I second the Bilstein/Eibach Pro-Kit combo.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
