Help, rear passenger tire axel area knocks when accerlated hard
Old Mar 14, 2005 | 08:04 PM
JD1990camaroRS's Avatar
Car: 1990 Chevy Camaro RS
Engine: 3.1 soon to be 305 or 350
Transmission: auto 700R4
When I hit the gas hard on my 1990 rs a loud knock or thud comes from the rear passenger tire area( only one knock or thud every time i hit it hard, no a bunch or anything just one intial knock ), i have been told maybe sway bar bushings, or shock in back , possibly even a transmission mount, also if i kick the top of the rear passenger tire it moves in some and bounces back out, any help would be appreaciated, thanks
Old Mar 14, 2005 | 11:12 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
control arm?
Remove the wheel, might make it a little easier, just a little....
Old Mar 18, 2005 | 04:26 AM
Fastrnu's Avatar
Car: 92 RS
Engine: H/C/I/E LS1
Axle/Gears: 4.10
I've had a similar problem in three different 3rd gens. All three were the tranny mount.
Old Mar 22, 2005 | 08:16 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Sounds like a broken swaybar ENDLINK to me.
Old Mar 23, 2005 | 06:35 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
It's likely that it's a busted tranny mount and it only sounds like it's coming from the rear. Either that, or having your car lowered w/o LCA brackets may do it as well.
Old Mar 24, 2005 | 12:49 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I "third" or "fourth" or whatever the tranny mount. Same thing was wrong when I got my car.
Old Mar 24, 2005 | 07:51 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I got a good deal on my first bird because the guy didn't know what to do about the noise. Ended up being tranny mount.
Old Mar 24, 2005 | 10:43 AM
dopplereffect's Avatar
Car: 91 firebird TBI
Engine: Three SLow Five. LO3
Transmission: MAN 5 SPD B0RG WARNER, 77MM, 2.95
ok i have the same prob but i just had the tranny mount replaced last year maybe even shorter than that. some one told me it was the motor mounts
Old Mar 24, 2005 | 01:04 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
the mounts dont last long at all esp if you are hard on the car, so it could have ripped again. put a energy suspension poly mount in there and it will never rip again.
Old Apr 26, 2005 | 12:20 AM
LB9_IROCZ28's Avatar
Car: 86 IROC / 84 TurboZ
Engine: 5.0 TPI / 2.2 turbo
Transmission: T5 / A413
I've had a similar sound come from a few different things. Panhard, control arm, and trans mount. Check the torque on the bolts too. Don't overlook the exhaust as well.
Old Apr 26, 2005 | 02:46 AM
FocusGhia's Avatar
Car: 88 Camaro IROC T-Top - Gunmetal Grey
Engine: 305 TPI V8
It was the swaybar endlink bushing on mine, passenger side.
Old Apr 28, 2005 | 11:24 AM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Control arm bushing on mine. Horrible knock that I chased for a while. Just pull them laterally back and forth and check for movement.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
