Who is not running a front swaybar on the street??
Subscribe
Mar 16, 2005 | 10:56 AM
I am thinking of removing my front swaybar to run at the drag strip. I do however have to drive my car to the track.
My question is, how will this make my car handle on the street?
Its not a daily driver, but I do take occasional drive in it. I know I will have to be easy in the corners, but will this make the car awful to drive?
Reply 0
Mar 16, 2005 | 08:03 PM
well my car is slow, but i dont have a front sway on anymore and i have 70/30 drag struts with the prokit on. 50/50 shocks in the back with stocker 24mm bar.
i still take turns hard.
sometimes i forgot i dont have it on, i daily drive mine also.
braking and everything still works fine.
Reply 0
Mar 16, 2005 | 09:29 PM
I removed mine on both the third and 4th gen and it's pretty much like what MD said. The biggest difference is with shock settings.
Reply 0
Mar 16, 2005 | 09:49 PM
got no front sway bar and some really worn out front struts, car is driven everday around some pretty scary turns. just can't take them at 70mph like i used to in the RS. i don't believe i will be putting it back on anytime soon either, thing weighs like 15-20lbs.!
Reply 0
Mar 16, 2005 | 10:20 PM
never thought I'd use that icon
Been covered countless times, you've heard from a few others and I will even attest you will not even notice it's gone.
Reply 0
Mar 17, 2005 | 08:18 AM
Re: Who is not running a front swaybar on the street??
It will ruin your handling, bringing it down to Buick or Lincoln Towncar levels.
Reply 0
Mar 17, 2005 | 08:32 AM
I did!! Just wanted to get some info first hand.
I have sagging springs and worn struts and shocks also. The car does have good weight transfer, but I think I will take the sway bar off. I can always put it back on.
Thanks guys for the info. Now if I can just get my garage floor poured and it warms up a bit. Track opens first of april.
Reply 0
Mar 17, 2005 | 10:12 AM
it's a 10min. job to take it off, so i would just take it off, and if it bothers you that much for street (heck, most street cars that see alot of drag use i know of, don't go around turns fast) that stuff it back on, you've waisted what, 20mins? i take that long to poop. then, after you get to the track, just unbolt the endlinks.
Reply 0
Mar 17, 2005 | 10:16 AM
Quote:
Yeah, I will take it off and leave it off. What little driving on the highway, it wont matter.
I have the one off my 92 parts car that I never put on. Its much bigger than my stock 89 one. Might have to sell it since I wont be running it.
Reply 0
Mar 17, 2005 | 10:47 AM
Re: Re: Who is not running a front swaybar on the street??
Quote:
Reply 0
Subscribe
