Installing Lower control Arms
Old Mar 22, 2005 | 08:34 AM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
O.K., I've finally purchased a set of lower control arms. After lots of searching, heres what I came up with for installation:
1)Jack car up and support rear end on jackstands.
2)Remove wheels to create needed working space.
3)Remove and install control arms one at a time.
Now the question I have is this. Some have said not to tourqe the bolts until car is back on the ground.
If I have the car supported on the rear end can I tourqe the bolts then? Or do I have to put the wheels back on and lower the car back to the ground?
Old Mar 22, 2005 | 04:12 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
what type of bushing??
Old Mar 22, 2005 | 04:38 PM
ator's Avatar
Billet aluminum bushings with steel inserts
Old Mar 23, 2005 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can tighten those while the car is up in the air.
RBob.
Old Mar 23, 2005 | 06:42 PM
ator's Avatar
Cool, Thanks
Old Mar 24, 2005 | 12:46 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I hope you never have to change your rear end for anything.
Old Mar 24, 2005 | 06:35 PM
ator's Avatar
Why?
Old Mar 24, 2005 | 06:58 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
BE SAFE!!!
I would not support the rear end with jackstands!!!
Put the jack stands under the chassis.
When you unbolt the contol arms even one at a time the rear end and body are going to shift in relation to each other. You want to support the biggest weight the chassis.
You will have to pull the chassis and rear end back together to get the bolts in.
It is easer to move the rear end than it is the chassis so you want the chassis in the fixed position.
Put a floor jack under the rear end to manipulate the arms into position.
When you take out the orginal arms wiggle them to open up the space between the mounting tabs. If you dont do this it can be hard as hell to get the new one in. After you have ALL OF THE NEW arms bolted in loosley, then tighten the bolts to spec. This will close the gap back up.
I would get them as tight as possible because the bushing is supposed to rotate in itself not on the bolt. It the bolts are not tight, the arms will rattle and foot ball the mounting holes and you will have a mess.
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
The_Phoenix
Feb 4, 2016 07:10 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
toronto formula
Nov 10, 2015 06:17 AM
