anyone with eibach pro kit please help
Old Mar 25, 2005 | 10:00 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
i had an eibach pro kit installed this week. i was under the impression it would lower my car 1"-1.5". the car is at the same height.
why is this? does it need to "break in" or something? does it not lower like i was lead to beleive?
Old Mar 25, 2005 | 11:16 PM
CrazyHawaiian's Avatar
Car: too many ...
It will take some time for the springs to settle. I've always run used progressive rate springs, so I didnt have to wait. But I've read about other people using new ones and the springs taking a few weeks to settle. There are also a few other things to consider when measuring the new ride height. If your old springs were worn out and sagging, then the car was sitting lower than it did from the factory. The advertised drop heights are in relation to the stock height, so replacing sagging springs with drop springs might not drop the car as low as you thought it would. Another thing to consider is the spring isolators. If your old springs didnt have isolaters, and the shop that installed the new springs added spring isolators (which is the right way to do it), then that will cause the ride height to be a little higher (not much but a little). All three of those things combined can give you the feeling that the car didnt drop as low as it should have. I say give it some time and see how it looks in a few weeks.
Old Mar 26, 2005 | 03:56 AM
sinner's Avatar
ok, cool. i kinda wondered if since it was new it needed some time. thanks alot!
ive been through alotta crap with this car and work geting done right, so i get pissy and defensive pretty fast
Old Apr 2, 2005 | 01:46 PM
Abubaca's Avatar
Keep us updated. I'm still up in the air as to which springs to use. Pro-kit or sportlines.
Old Apr 2, 2005 | 09:19 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I went from a new set of WS6 springs to a used set of Pro Kits. Front end was always a little bit higher than the rear. Hoped the Eibachs would fix it but nope, still sits the same. Very dissappointed.
Old Apr 2, 2005 | 09:36 PM
Abubaca's Avatar
Lots of people have cut half a coil of the front of the Pro-Kit from what I understand.
Old Apr 2, 2005 | 09:47 PM
Engine: LB9/383
I know I am tomorrow as long as it doesn't rain.
Old Apr 4, 2005 | 06:23 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Were the springs indexed correctly when they were installed? If not, it will definitely affect the ride height.
I had the pro-kit in my RS before I sold it last year, I liked both the ride and the ride height. Sportlines, in my opinion, are too low for street. Looks cool and all, but having to crawl over speedbumps, dips, potholes, etc. gets a little old after awhile. Even with the pro-kit, my SFC's would occasionally scrape over high speed bumps.
Old Apr 4, 2005 | 08:00 PM
Engine: LB9/383
I know mine are indexed right. Sometimes it's a pain to get them right and get them to line up in the upper pocket too.
Old Apr 7, 2005 | 08:05 PM
sinner's Avatar
should i go question the shop about this? it does seem a touch higherin the front, and they havent settled any at all
Old Apr 8, 2005 | 01:27 AM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
I threw a set of sportlines in the rear and set it on the ground to see how they were and they were VERY low. I mean the rear end looked like it woulda scrapped a ton. I never tried the front sportlines, I just returned those for the prokit. So I would recommend the prokit.
Old Apr 9, 2005 | 02:06 AM
sinner's Avatar
alright, ill go with it 4 a while and c if i like it
Old Apr 9, 2005 | 08:51 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
post a pic that will help us tell if its right for a pro kit stance....
Old Apr 9, 2005 | 10:09 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
i bought a prokit specifically because i knew it wouldn't change my ride hieght much. i have a 82 T/A and the springs were so wore out, you could compress them 3/4 by hand. and the ride and handling from the prokit is unbelievable compared to the stock wore out crap i had. give it time. my front and rear are the same height, but yours may be different. good luck.
Old Apr 9, 2005 | 06:41 PM
Engine: LB9/383
I just cut 1/2 coil off my pro kit today, dropped it to the perfect height. I'll post a pic as soon as I get it hosted.
Old Apr 9, 2005 | 07:15 PM
Engine: LB9/383
Here we go
Old Apr 10, 2005 | 08:28 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Finished install yesterday. Got about 1.5" drop in front and nothing noticeable in back. Had 114K mile WS6 springs in the '89.
Old Apr 10, 2005 | 09:14 PM
Z RATED IROC's Avatar
Car: 89 Camaro
Sometimes if the anti roll bar end link bushings are polyurethane and overtightened the car will not settle down to the correct ride hight
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Chiknhawk
Sep 10, 2015 08:55 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
