bump stop to tire clearance
Old Apr 11, 2005 | 10:54 AM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
what do you think the safe minimum clearance from the tire to the bump stop in the static condition that would provide for no contact during suspension movement.
thanks
Old Apr 11, 2005 | 01:01 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
In the rear?
Why not just test it? Put the body on jack stands, then let the rear end droop to see if the tires will hit the bumpstops, that way you know if the tires will hit the bumpstops at full travel.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
skip91
Sep 24, 2015 03:29 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
