Anyone got a lightly used set of stock tierods and/or balljoints?
Old Apr 10, 2005 | 04:14 PM
wpaskar's Avatar
Car: 1985 2.8L V6 Camaro
Engine: 2.8L V6 multiport
Transmission: 4-speed automatic
Hey guys...I found out a lot of bad things about my camaro yesterday. So, as a result I am going to buy another one as soon as I get enough cash for a decent one. But until then, I need to keep this hunk of junk going...if someone has tie rods or balljoints i can get for cheap to put in this thing so I don't die while I am saving money, it would be appreciated. Lemme know. Thanks
Old Apr 10, 2005 | 05:29 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I got a set of ball joints that have only 1,000-1,500 miles on them...I`ll have to press them out of the arms but you can have them for next to nothing if u need them
Old Apr 10, 2005 | 05:56 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I really do not suggest putting used parts on for this... You can buy all new tierods and lower ball joints at Canadian tire for probably under $150 in total. I buy my stuff from local jobbers, Ball joints usually average from $15- 30. and Tierods from $25- $50. Go new, don't mess with used, it's not worth the trouble.
Old Apr 10, 2005 | 07:02 PM
wpaskar's Avatar
Yea alright..I had no idea they are that cheap. But if you going to have them mechanic installed, how much would you pay for complete balljoint/tie rod replacement? I heard as much as 400-600 Canadian dollars from someone. I am a rookie to this game still and I don't know better, but I am guessing that's probably not true now ...but thinking it could actually be that much is why is why I started this thread in the first place...
Old Apr 10, 2005 | 07:14 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
installing tie rods are usually not hard at all, and require few tools, and 1 tool you can "rent" from autozone.
Ball joints are for professionals, or heavly tool equipped and experienced person.
Then get an alignment.
Old Apr 11, 2005 | 07:19 AM
wpaskar's Avatar
how much would you pay to get the balljoints done?
Old Apr 11, 2005 | 10:16 AM
Dale's Avatar
Engine: 350 S-TPI
I've called, but I cant remember the prices. Just start calling around to shops you trust.
When I called, I also was getting quotes for the a-arm being out of the car. Sounds like yours will still be in the car.
Old Apr 11, 2005 | 10:29 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
The lower Ball joints call for 1.5 hrs labour, so the average shop should be around $100 to R & R both ball joints. our shop is $70/hr, so it would cost $105 for labour only.
Old Apr 11, 2005 | 01:41 PM
wpaskar's Avatar
Alright, that is sounding a little better than what I heard..thanks guys. I am still getting over the shock of what I heard about my car..basically, shops I have taken it to before have stiffed me (didn't even do the work requested and charged for it) and/or charged too much. I felt very used when my new honest mechanic told me all the bad news...but I forgot to ask him about the ball joint/tie rods. My car has quite the list of things busted, such as a broken left engine mount, etc...to deal with. Oh and the fact that one of the shops broke off the contact points on one of the spark plug wires..so i was running on 5 cylinders for part of the time, six on others....I am pissed. I am trying to learn as much as I can as fast as I can, but until I do, even a car shop such as A CHRYSLER DEALERSHIP (my mom was paying as a present and insisted it go there...), can screw me over if they want to. I am out to kick some ***. Thanks again.
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
camaro71633
Sep 1, 2015 10:24 AM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
