Widest tires on OEM 16"
Old Apr 2, 2005 | 05:50 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I did search and did not find exactly what I was looking for.
I have an 86 TA with 15" wheels (and 255 back) but I have a full set of OEM 16" wheels I want use (not GTA style). I have heard that I can use 255/50R16 on the rear end and 245 in front.
I would like to have a little wider tires than that on the rear end of my TA.
A friend told me I can use much wider tires. He said he used to have 295 (but he is a kind of ******* and dont care if it rubs).
I was thinking of more like 275/50R16 (I dont want the tires to stick out), will I run into some problems with that?
One more thing, I dont have the spacers for the 16" wheels, do I need them?
Thanks, Nonni
Old Apr 4, 2005 | 05:49 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
ttt
Old Apr 4, 2005 | 05:59 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
On the OEM 16" wheels, 255 is about as far as you want to go. Anything wider will stick out beyond the rim and look silly. I have 245's on my 16's and I like the appearance. Then again, I'm not making crazy horsepower (stock 305) and don't really need anything wider.
If 275's don't stick out, which I don't see how they would not, they'll certainly not look right, and I'm not sure how your friend even fit 295's on the rim!
Old Apr 4, 2005 | 10:26 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ive run a khumo(SP) 255 55 16 light truck tire.
they last forever, and really fill out the tire well nice.
hook pretty decent for a radial too.
(400hp here)
Old Apr 5, 2005 | 02:47 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Thanks, then I probably will stick with 255s (and 245 front)
Twin_Turbo
Mar 14, 2016 10:10 PM
customblackbird
Oct 1, 2015 04:30 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
