Why solid bars are better than hollow ones
Old Apr 2, 2005 | 07:59 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
So I came outside this morning to my car not starting, hood struts shot when they were good yesturday, and this:
Their is a 3pt edelbrock stb, and a wonderbar on there and I managed to snap the thing?
The only undue stress I can think of is yesturday I took a corner too fast in the rain, and hit some sand. I went into a spin but got it under controll fairly quickly.
Has this happend to any of you guys or is it just a freak thing? I'm debating weather to throw on the spare 36mm hollow I have or the 34mm solid.
Edit: Looking at the pic now it looks like it's rusted out inside the bar, maybie that's what did it in although the metal on the break is clean.
Old Apr 2, 2005 | 08:11 PM
kevinc's Avatar
Car: 1982 Z28
I've been road course racing with hollow GM bars for years now, sticky track slicks and bumpy tracks like Lime Rock and Pocono...never snapped a swaybar.
There was definitely a contributing factor in your breakage, maybe the internal rust as you pointed out or something else going on.
Old Apr 3, 2005 | 01:05 AM
Spdfrk1990's Avatar
Not good that makes me want to buy some spohn bars lol.
Old Apr 4, 2005 | 07:46 AM
laiky's Avatar
I the upper left hand corner of the bar, it looks like it might have been cracked. Not surprising considering that is where the bushings wear. Take a good look at the break, i bet there is a deep scratch on the outside near the break. I wouldn't hesitate to put the hollow 36 on there, but i would (as i am planning to do) polish it up, remove all paint, inspect for cracks and repaint it.
Old Apr 4, 2005 | 10:03 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I'm still trying to figure out the connection between the broken sway bar and engine not starting and hood struts bad. Why a broken sway bar would cause those other problems is beyond me. lol
Lon
Old Apr 4, 2005 | 10:45 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Lon
Well I was running fuel through the swaybar to expand the capacity if the tank, so that would explain the not starting. I'm still lost on the hood struts though.
Old Apr 4, 2005 | 11:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
you can run fuel thru the swaybar??????????
Old Apr 4, 2005 | 11:22 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Are you for real?!?
Old Apr 4, 2005 | 12:01 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Originally posted by iroc-si
Are you for real?!?
What do you think?
Old Apr 4, 2005 | 12:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Actually PyRo9862 has a hidden nitrous system and stores the funny juice in the sway bar. He's only saying the fuel runs through it to throw us off.
I'd check the bushing to bar interference. It may be that the bushing was binding preventing the bar from twisting. That would defintely shear it (and allow the N2O to escape negating the effectiveness of the nitrous system ).
RBob.
Old Apr 4, 2005 | 03:26 PM
83 Crossfire TA's Avatar
I thought that it was helium or hydrogen to lighten the front of the car a little bit…
Old Apr 7, 2005 | 12:25 AM
VILeninDM's Avatar
Lon
The only thing that comes to my mind is maybe an angry neighbor. You didn't borrow any tools you forgot to return, did you?
Old Apr 7, 2005 | 01:52 AM
Spdfrk1990's Avatar
Im thinkin vandalized
Old Jun 7, 2005 | 10:07 PM
chrisamero's Avatar
Car: 1988 formula firebird
Engine: 305 tpi
Transmission: world class 5 speed
broken 36mm sway bar
just the other day i broke my 36 mm sway bar in the same location and probably from the same reason, rust. i came across this just from the corner of my eye one morning and i was amazed to see it broken, well i got another ready to bolt on asap. I'll post a pic asap.
Old Jun 8, 2005 | 04:56 PM
chrisamero's Avatar
Engine: 305 tpi
36mm broken sway bar
here it is.
Old Jun 8, 2005 | 06:43 PM
semiller26's Avatar
Car: 1986 Trans Am
glad i live in california! my bars have no rust, the car too.
Old Jun 8, 2005 | 10:56 PM
Spdfrk1990's Avatar
Glad my car will be in the garage and never see rain again I hate rust altho it is kinda fun to fix sometimes.
Old Jun 8, 2005 | 10:57 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Looks like that's been broken awhile, maybe that hard steering just popped it out of the mount.
OR...you built up too much under hood heat and it radiated into the sway bar causing the NOS to overheat and force it's way out Next time install a sway bar internal pressure gauge and keep the pressure at about 1000psi.
Old Jun 9, 2005 | 02:16 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
what he said ^^^ lol
Old Jun 9, 2005 | 03:54 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Wow, that looks awful.
Old Jun 11, 2005 | 07:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Alot of times the tire rubs on the bigger sway bar under severe turning(u-turn,Lk to Lk).Perhaps when you spun out in the rain.The tire may have been rubbing while rotating & exerting a little too much force on the swaybar.Thereby shearing it off at the mounting bracket?Extreme example,but plauseable?perhaps!Maybe?
Old Jun 12, 2005 | 06:10 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I've never heard of them rubbing. Interesting theory but it was a left turn and the left side broke so if either side was rubbing it would have been the right.
Old Jun 12, 2005 | 07:49 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
How do you know if your swaybar is solid or hollow? My front swaybar is the ginormous one (36mm, I think. Been a long time since I measured it, and I don't have a metric caliper)
Old Jun 12, 2005 | 08:45 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Running fuel threw the sway bar must be kidding.
but it is as funny as the person
who said he used a hole saw to cut holes in his
unibody frame to lighten the car and I think
he really did turn his unibody into swiss cheese.
Old Jun 12, 2005 | 09:59 AM
black89ws6's Avatar
Of course he's kidding. You can't run fuel through your blinker fluid reservoir like that. C'mon, everybody knows that.
Old Jun 12, 2005 | 10:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If it was a left hand turn & you spun out.That means the rear of the car swung to the right.Making the front tires point as if you were turning right.This could make the tire rub on the bar(they do rub).Assuming you didnt let go of the wheel of course.
Old Jun 13, 2005 | 08:18 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
All 36mm bars from the factory are hollow. Look near the ends of the bar, you will notice drain holes.
Old Jun 13, 2005 | 11:34 AM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
Drain holes? Thought those were pressure relief valves from the factory...
You know GM thought of everything.....
Old Jun 15, 2005 | 12:07 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Dude I was thinking the same thing. Damn I thought my car was dirty and ****. Until I saw some of these midwestern rides. **** you guys have ti bad.
Will
Old Jun 17, 2005 | 10:41 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Thats not right, some WS6's had solid and some had hollow bars.
Old Jun 17, 2005 | 11:15 AM
Engine: 5.7, 5.0
really, a solid 36mm sway bar, huh. learn something new everyday i guess.
Old Jun 17, 2005 | 11:24 AM
91Z28-350's Avatar
All 36mm GM sway bars were hollow. The 34mm was available as solid or hollow from GM.
Old Jun 17, 2005 | 11:31 AM
Engine: 5.7, 5.0
that's what I thought. Now the question is, did any WS6 cars come with 34mm bars?
Old Jun 17, 2005 | 11:50 AM
91Z28-350's Avatar
Not that I know of, no.
Old Jun 18, 2005 | 10:38 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I've seen solid and hollow 36mm bars.
Old Jun 18, 2005 | 11:17 AM
91Z28-350's Avatar
Interesting, the only solid 36mm I've seen are aftermarket. I've never spotted a solid 36mm at the junkyard. I just did a search, and nobody on TGO has heard of solid 36mm OEM pieces neither. Do you have a PN for the solid 36mm?
Old Jun 8, 2006 | 03:12 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
reviving from the dead...
I just got a 36mm SOLID from an 85 WS6 t-top car. No part # on it. Looks like its been there its whole life.
Old Jun 8, 2006 | 11:06 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
they are out their, but i have never seen one.
how much more does it weigh compared to the hollow bar?
Old Jun 8, 2006 | 11:39 PM
Car: 85 Trans Am
ill weigh it tomorrow, its heavy
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
