mmm...poly end links
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looking to burn my small amounts of cash, i picked up some Energy suspension poly end links for my Sport Coupe.
Installed them will no hassle in about 25 minutes, my kinda deal.
Anyways... with the old sagging, worn out stock springs, and some sweet gabriel struts/shocks, I took her for a spin.
The front end was noticeably more responsive. They didn't help in ride quality, but handling was a notch better. Seemed to have a little more steer in the bendies.
Well, now I'm a firm believer in the gift of Polyurethane, and will soon get a set for the rear sway bar, and start saving for some new shocks/struts/springs.
over and out,
Brandon
over and out,
Brandon
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
After I put poly links on the front and back of mine, I was a believer too. Also Advanced sell HD versions of our links that are poly that run $6.13 a set. A bargin in my eyes.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
If you noticed that much difference in the front links, wait til you get the rear links installed. Those made a huge difference on my car. Then again, I have the 36/24 WS6 combo on my car.
The rear swaybar mounts made a big difference too. I'm going to be ordering some front swaybar mounts and a torque arm mount mid-way through this week when I have time.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
They even work better if they are actually torques to spec too :-)
I believe its roght around 15-17 ft lbs depending on your suspension, WS6 or not.
I know the spec sheet has been posted here too, I cant find mine at the moment
Just something to note, since people here never like to torque anything.
later
Jeremy
later
Jeremy
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
db057
Aug 11, 2015 10:11 PM
