motor mounts from hell!!! NEED HELP ASAFP
Car: 91 firebird TBI
Engine: Three SLow Five. LO3
Transmission: MAN 5 SPD B0RG WARNER, 77MM, 2.95
okay fellow LO3s what is the proper way top change out the motor mounts because so far my neighbor and i are considering lowering the lower control are to get to them i need help asap iam exhausted on ideas
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Lowering the a-arms is the prefered method. I have some special 15mm bent wrenches that did the job for me. I don't have to worry about them any more. My engine now uses a front motor plate to mount the engine to the frame.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
15mm or 9/16 flex socket works wonders.
U can also access the bolts thru the springs(access hole in frame) if u take the time to look.
Doesnt take that long and if u uses some dum dum or equivelant on the socket to hold the washer /nut in place it goes even quicker.
U dont need to drop the a-arms.
later
Jeremy
later
Jeremy
Car: 87 IROC L98
I guess I should have added that my bent 15mm wrenches did the job for me without dropping the a-arm.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
