Why with the noise!
Old Apr 19, 2005 | 07:24 PM
Faded's Avatar
Car: '91 Firebird
Why with the noise!
My car was in my garage for awhile. In the time it was in there I :
-replaced the auto with a manual tranny
-Installed Subframe connectors
-New Lower Control Arms
-Wonderbar
-Rehung the exhaust
After all this I have driven it around a bit and there is this godawful noise coming from the rear of the car... Like something is extremely messed up. Whenever I go over the slightest bump I'm greeted with a very loud BANG.
I have inspected everything under my car. Nothing is loose. The exhaust is still hanging fine... the crossmember is tight and the bushing is OK... I'm at a complete loss. I even replaced the rear suspension with Coil-Overs to no avail.
The only thing I could possibly still think it could be is the new LCA's. I got the Adj with Rod Ends and not Poly Ends. Spohn's site said they can cause more road noise but this sounds like I just jumped a curb.
Can anyone give me any advice? My car sounds like it's going to fall apart... I'm seriously considering selling it if I can't figure this out...
Old Apr 19, 2005 | 09:01 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Not sure how the bushings are installed in the Spohn LCAs, but did you make sure there was something in the rod end?
That's about the only thing i could see banging unless you pulled a moron move like me and hung the exhaust with those rubber hangers. Mine moves around quite a bit with those.
Old Apr 19, 2005 | 09:31 PM
Faded's Avatar
Car: '91 Firebird
Here's what they look like:
What do you mean about making sure there was something in the rod end?
Old Apr 20, 2005 | 12:15 AM
nape's Avatar
Ahhh, I see how Spohn's reducer bushing works now. The ID of the rod end is probably 5/8" ID and Spohn used a piece that probably has ~5/8" OD and 1/2" ID as a reducer, then has the spacers slid over it.
Probably not that thunking.
Did you take the bump stops off the car and it's bottoming out?
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
