Visible difference in quick ratio vs. normal steering box/gear?
Old Apr 21, 2005 | 01:02 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Ok, I know the difference, but is there a visible difference by looking at the box? I know some people said that it says 'Z' on it, and others said something different. I'm just wondering because I need to replace my steering box, and at autozone they list a normal and a 'performance' quick ratio. I'm pretty sure I have the normal one, but I want to buy their quick ratio. Is there any visible difference, or would they not even care as long as they get their core? I'm sure they'd just rebuild it with quick ratio internals anyway. Any input would be appreciated, thanks.
Old Apr 21, 2005 | 02:07 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
When I switched to a quick ratio box I compared it to the stock one from my '91 RS. Both looked identical on the outside. Both had a 'Z' cast into them. The only difference was the serial number. At first I thought I may have gotten another standard steering box, but sure enough, when you turn the pitman arm, the steering shaft only goes 2.25 turns lock to lock versus 2.75 for the stock one.
Old Apr 22, 2005 | 11:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Unless the ink stamped letters are still on the box, the only visible method of identification is internal. Not even lock-to-lock turns means anything. See this thread for more information:
https://www.thirdgen.org/techbb2/sho...hreadid=275037
RBob.
Old Apr 22, 2005 | 02:35 PM
Hg's Avatar
Hg
Car: '87 Z
Thanks guys. I'm hoping most if not all of my problem is in the steering box.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
happyhapka
Aug 15, 2015 04:42 PM
