Dogtracking ?
Old May 9, 2005 | 10:51 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Dogtracking ?
I just want to understand this
You say when the car is lowered the as& end sits to the drivers side? Do you mean the rear axle moves over to the passenger side and there’s more space on the drivers side between the tire and the outer fender than the passenger side?
For sportlines how much should I lengthen the Panhard bar? An inch or so ? just to get it in the ballpark before final adjustment?
Thanks.
Old May 9, 2005 | 11:13 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Dogtracking ?
I've seen this on all third gens even with stock suspension. It's just more noticable with wider tires.
Old May 9, 2005 | 04:14 PM
KillerRS's Avatar
dog tracking or dog legging is when the rear axle is not perpendicular with the geometric centerline. If you have ever seen a truck that looks like it is going doen the road sideways, it is dog legging
Old May 9, 2005 | 05:58 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I had my dog aligned. Or was that neutered?
Old May 10, 2005 | 01:01 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
so when i lower my car with sportlines, what side is the rear axle going to move to??
And this adj PHB came at stock length, how much should i lengthen it before putting it on ??
also i just realized the upper panhard bar is a piece of crap,
Old May 10, 2005 | 03:36 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Ideally, you should adjust it on the car. What brand PHB did you buy? The Spohn PHB let's you easily make adjustments on the car and in small increments so you can fine tune.
Other brands require you to do trial-and-error by disconnecting one end, turning the bushing (either a full or half turn), then reconnecting.
Old May 12, 2005 | 12:48 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
ITs Spohn adjustable. So I just put it on, let the car down and start adjusting it ?
Old May 12, 2005 | 02:44 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
mine sits more the driver side and i still have the stock suspension. Does it need to be adjusted?
Old May 12, 2005 | 04:19 PM
Car: Yes...
With the car lowered, it might be a bit tough to adjust the PHB with the car sitting on the ground. Not much room to work.
I adjust mine by jacking up the rear of the car by the axle. This keeps the rear suspension loaded and gives you room to make adjustments.
I recommend using some type of straight edge to hold vertically against the outside edges of the tires, so you can see how much the axle needs to be adjused.
Old May 12, 2005 | 06:10 PM
83 Crossfire TA's Avatar
Drive the back tires up on ramps, if you’re really **** do it with the front end up a hill or jack the front end up some so it’s sitting level. As far as measuring it, hang a plumb bob (or any piece of string with a weight on it) over the edge of the top of the rear fenders and then just measure from the wheel or tire over to the string on both sides till it’s even.
Old May 13, 2005 | 07:13 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
haha...
project25thanni
Exterior Parts Wanted
Oct 23, 2010 07:07 PM
AlkyIROC
May 13, 2005 08:06 PM
