Name that tool.
Old May 11, 2005 | 09:35 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Name that tool.
What is the name of the socket which is used to hold the strut shaft in place while tightinging the nut(so the nut and shaft dont turn as one)? We have a set out at school and im looking into purchasing a set for myself.
where is the best place to buy a set of these sockets?
what are the most common sizes?
what are they called?
they are a socket that fits over the shaft where its shaped like this...
Old May 11, 2005 | 11:37 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Vice grips
Old May 11, 2005 | 11:42 AM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Originally posted by Forshock 85TA
Vice grips
Old May 11, 2005 | 02:32 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Vice grips
Two pairs of vice grips.
Old May 11, 2005 | 04:15 PM
91Z28-350's Avatar
hehe, funny...
it's a shock absorber/strut socket or tool. Here's a common one. http://www.lislecorp.com/tool_detail.cfm?detail=200
Old May 11, 2005 | 08:10 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
You don't need to hold it if you have an impact gun..
Kevin D.
Old May 12, 2005 | 01:06 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
It does make it so much easier, then you don't have to worry about stripping the stupid little hex hole either
Old May 12, 2005 | 11:33 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I think I used an adjustable wrench to do my shocks. Two adjustable wrenches actually. One for the shaft, one for the nut. I'd suppose vicegrips would work as well
Old May 13, 2005 | 12:11 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I don't see why a box end wrench and hex wrench can't be used?
Old May 13, 2005 | 12:46 AM
Mr Badwrench's Avatar
Car: 88 RS
Engine: 2.8 untill the 3800 swap
http://buy1.snapon.com/catalog/tools...e=snapon-store
Old May 13, 2005 | 02:27 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
hmmmm, i didnt know they made that, pretty cool. i just always used a cresent wrech and an open end. time consuming, but it works
Grumpy
Apr 27, 2009 01:46 PM
a73camaro
Nov 24, 2003 02:41 PM
Beast5spdGTA
Sep 10, 2003 06:22 AM
mdricken
Jul 26, 2003 08:15 AM
shaggy56
Jul 28, 2002 10:28 PM
