just won these on ebay for 70 bucks
did i do good? thats with shipping....
after market third gen camaro rear control arms . These have the hiem joints ends . They are fully adj . They really tightin up the back of your camaro. I think they are SLP , but not shur . They came on a car that i parted out . No bushing , they are heim joint ends . They adjut using a jam nut design . These are in great shape , everthing moves freely . They have some road grim but that all
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks like Herb Adams parts. The LCA's are worth about $200. I can't remember what the panhard is worth.
I sold my LCAs a year or 2 ago but still use the panhard bar.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
You probably did decent for the tubing, bushings, and jam nuts if the tubing is aluminum.
The rod ends (heim joints) are probab35*ly shot though. You're looking at 6 of them at $35/each for the good ones (QA1 teflon lined).
said everthing moves freely, would that even matter, oh btw i was on BMRs site and the ones like the ones i bought say race only, well there be a more haruser ride on a everyday car? whats the diffrents? between these and the ones with poly ends?
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
o yeah your ride is gonna be more harsh , you have solid links now , so it will be lourder too , youll get all the road noise.
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I hate to tell ya but the rodends are most likely shot. They look pretty banged up in the picture and of course they will "move freely" when they are more worn, they don't get tighter.
Those tube arms can be bought in either aluminum or steel for about 15$ per arm through Coleman Racing and for about $20 for the longer panhard rod tube. The rodends and jamnuts are what are going to cost you to replace and you had better use the QA1 stronger quality ones like Spohn offers. By the time you are said and done you will be spending more money for those used tubes and new rodends than you would have just buying new Spohn units.
Car: Agood2.8,
Engine: V6rsr,
Here's some info and pricing on rodends so you can understand the quality difference and what good rodends cost.
This info was posted and comes up easily under a search
https://www.thirdgen.org/techbb2/sho...hlight=rodends
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Yeah rod ends that "move freely" aren't in very good shape. That'd mean they have some play because new rod ends need a bit of force to move (not difficult...I just wouldn't say they 'move easily').
As stated, expect to replace each of them at $35/each. Jam nuts are fairly cheap, $2-3 each or so. That's $228+70 = $298. Right around the same price as Spohn.
On my car, I'm staying with poly LCAs for now. I haven't installed them yet, but they are sitting in my garage waiting to be installed. I'll probably put them in the same time I put in my new rod-ended aluminum PHB that I should be picking up in a few days
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I would get poly lined rod ends for the chassis side. Thats what i used when i built my arms and panhard just like that. The poly ends are cheap, $15.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'd go with summit rod ends.. $11 each with jam nut.
-- Joe
Car: 1997 Corvette
Originally posted by anesthes
$35 for rod ends?
-- Joe
$35 for rod ends?
-- Joe
Ask the other Dean (RTFC) about rod end quality.
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
FYI, speedwaymotors.com has the good 3/4 QA1 rod ends for $25 each. Part numbers 910-02336 and 910-2136. The $11 rod ends from summit just don't have the strength to keep the axle in the car. If money is the issue I would keep the worn out ones untill I had the money.
Originally posted by NEEDforSPEED
you dont think thos are thick?
e3pres
Sep 9, 2015 01:51 PM
