End Links
Old May 31, 2005 | 02:10 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
End Links
I am putting a set of end links on the front of my car at the moment and have a question. How tight do the end links have to be?. Do I tighten them to the last or just enough so that the rubbers on the end links just start to compress.
Thanks.
Old May 31, 2005 | 07:55 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
There is a torque spec for them, I dont have it handy right now.
Try searching for torque and sway bar endlinks
later
Jeremy
Old May 31, 2005 | 09:39 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
17ft-lbs, give or take 1ft-lb, I believe. I usually just keep tightening them though until it doesn't turn too easily anymore.
Old May 31, 2005 | 12:49 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I think the general thought on this board, if you don't have a torgue wrench, is that you tighten them until the rubber compresses to the same size diameter as the large washer on the end.
Old Jun 1, 2005 | 01:25 AM
83 Crossfire TA's Avatar
Tighten them till the nut contacts the shoulder…. It shouldn’t take much/any force at that point to keep them from backing off, so they don’t have to be that tight at that point
Old Jun 1, 2005 | 10:32 AM
gholian's Avatar
Engine: 2.8 V6
Thanks Guys for getting back to me.
1992rs/ss
Jan 31, 2025 05:10 PM
GTAman
Mar 15, 2019 11:40 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
