New suspension suggestions
Old Jun 18, 2005 | 10:54 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
On my rickety ol 89 Formula, I've gotten around to changing my shocks and struts. I'm thinking I should start to do a little more, since my car sags slightly (need new springs, but which ones?) when doing 90 on highway curves, and other times too. Anything that's worth replacing should be mentioned, as I see so many different things being added and moded. Just some stuff that might keep my car in better control, and keep the tires on the ground.
Old Jun 18, 2005 | 11:16 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Re: New suspension suggestions
What Struts/Shocks did you go with? I just installed a set of Bilstien HD struts/shocks, and an Eibach Pro-Kit, absolutly LOVE it. Highly recomend it.
also look at replacing bushings, and the Panhard bar with an adjustable piece, if you dont ahve a wonder bar, get one of those too, LCA relocation brackets would be a good idea too.
Old Jun 19, 2005 | 01:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i am running pro kit springs and adjustable tokicos shocks/struts and also love it.
i also got LCA's but not the brackets on yet.... and adjustable panhard bar from hotchkis to fix the rear alignment problem that the springs caused
also added some poly sway bar endlink bushings and the car handles extremely well
i just need lca brackets for abit more traction and wonder bar to fix my steering feel problem
Old Jun 19, 2005 | 01:28 AM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
A strut tower brace would give you a good solid responsive feeling.
Old Jun 20, 2005 | 07:29 PM
Sorry to say that I just installed the cheap new no-name shocks/struts when I first got the car. The old shocks/struts were doo doo and I needed something new in there and didn't know the difference or have the financial backing for these exquisite aftermarket shocks/struts. I'm not looking to do any drag racing, so what are some decent shocks/struts for me? Do I need to buy adjustable shocks/struts? I've found some adjustable ones on Summit from KYB, Koni, and Competition Engineering ranging from $40 to $125. My current shocks/struts work fine and are stiff on the biggest of bumps. Also, I'm new to the some of the car lingo, so what is an LCA, and what is a wonder bar? The adjustable panhard bars I've seen all look similiar, so is there a quality difference between edelbrock, hotchkis, and lakewood? I've also heard that replacing all of the bushings is worthwhile and if so, which ones should I get. Lots o' questions, but I'm a little curious.
EDIT: Where did you guys get your Pro Kit springs, and for how much?
Old Jun 20, 2005 | 07:39 PM
92MaroRS's Avatar
LCA=Lower Control Arm
If you are going to go with the Eibach pro kit i HIGHLY recomend gonig with the Bilstein HD struts and shocks, all 4 can be had for 419 + 20 shipping.
Wonder bar is a steering brace, it ties the front subframes together at the steering box and idler arm, keeps the geometry between the two the same. TDS makes the best piece on the market, costs $50.
Panhard bar i recomend going with a Spohn piece(site supporter) runs $125 + shipping. very good piece!
I got my springs from work, Advance Auto Parts, price is $248.88 + tax, no shipping charge, should have them one to two days after they are ordered.
Old Jun 21, 2005 | 01:57 AM
Found the springs for a comparable price as you stated. Those rear shocks are $80 each at Summit, but the front struts are harder to find, and are list price $389 each on Bilstein.com. That's real expensive for me, for each shock. I also found the 1021 and the 1121. The 1021 are "sport", is there any real difference? Price is the exact same. Wonder bar and Pahhard bar seem to be in the right price range. I should get the panhard bar with the poly bushings, and not spherical? For the LCA relocation brackets, should I get the front and "Moser" rear from Spohn? Are they a good brand/quality? And lastly, the strut tower brace, is it worth it? Thanks for all the answers
Old Jun 21, 2005 | 10:54 AM
92MaroRS's Avatar
Go to Shox.com, they have the best price ive seen on the bilstein's, you get all 4 for $419 + shipping, which was $20 for me.
with the pro kit, go with the HD, the valving is a bit different and seems to go better with the pro kit.
Id recomend going with poly instead of rod ends, unless this is going to be an all out track car.
Spohn is great quality, highly recomended by everyone on this board.
Old Jun 27, 2005 | 09:52 PM
Is there any specific order I should put these on? I know that springs take a week or two to adjust to the car. Which order would be the easiest, and most effective?
Old Jun 27, 2005 | 10:27 PM
92MaroRS's Avatar
all at once.
J-money
Jan 4, 2019 09:45 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
starfinder
Oct 25, 2015 10:40 AM
R13_Braz
Sep 18, 2015 05:00 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
