will 18x9.5 rims fit with coil overs
Old Jun 23, 2005 | 04:01 AM
89ta383sc's Avatar
Car: 89 ws6 trans am
Engine: 383 supercharged
Transmission: t-56
Axle/Gears: 9 inch 3.90's spooled
i am about to get some 18x9.5 c6 rims, and i wanted to know if they would fit on the front with coil overs. i am new here and could not find anything when i tried a search. thanx
Old Jun 23, 2005 | 07:56 AM
CrazyHawaiian's Avatar
Car: too many ...
If you get the right adapters and run a reasonable ride height it should fit with no worries. There are alot of guys running 275/40/17's on the front with drop springs and they are OK. If you run a 275/35/18 then you should have similar results. If you plan to really lower the car then consider smaller width tires like 255's or 265's.
Old Jun 23, 2005 | 10:11 AM
89ta383sc's Avatar
Transmission: t-56
what size spacer would i have to run? and if i change to c5 brakes will that make a differance on the spacer?
Old Jun 23, 2005 | 10:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
drop springs dont get in the way of the tire..
coilovers do...... if they'll clear his car or not, i donno.
Old Jun 23, 2005 | 09:36 PM
Car: too many ...
Hmm didnt consider that, and honestly I got no idea cuz I have no experience with coilovers. Guess it would depend on how much bigger they are than stock struts and how close stock struts sit next to a 9.5" wide wheel in the front.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
Derick15
Sep 17, 2016 05:28 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
