Need Part Numbers Please! (4th gen rear swap pieces)
Old Jul 4, 2005 | 12:26 AM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
Hey does anybody have a list and/or the part numbers for a 3rd gen '88 drum rear end to a '94 disc rear end?
thanks for any help
Old Jul 4, 2005 | 04:56 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You don't need part numbers. Just unbolt and remove the stock rear, install the "new" one.
Ed
Old Jul 4, 2005 | 11:20 PM
KBeez's Avatar
Car: 88 Camaro S/C
not even an e-brake cable? My dad mentioned a proportioning valve as well.
Old Jul 5, 2005 | 08:57 AM
ebmiller88's Avatar
Oh...OK.
Parts for your '88:
GM PN 14089496
Ebrake cables: Napa 94264
Master cylinder: (same as J50):18014286
The master will be the same as the one on a '90-92 car as they are all the same.
Ed
Old Jul 5, 2005 | 12:02 PM
KBeez's Avatar
Car: 88 Camaro S/C
Thanks a million!!!!! What's that first part number though?
And to make this clear, all I need is the master cylinder and the ebrake cables? 'Cause, like said before, the new rear is from a 93-96, disc, and my current rear is a drum brake in an '88 camaro.
I just want to make sure that's all I'll need Thanks for any help
p.s- do you by chance remember about how much that stuff costed you when you got it?
Old Jul 5, 2005 | 07:23 PM
ebmiller88's Avatar
First # is the 1LE prop valve. You may not need to install it but it won't hurt you if you do. You can always test out the brakes and see if they feel OK, then change it out if you don't like what you get.
4th gen rears bolt in just like 3rd gen rears. Take a look at my swap pics and you'll get the idea. I went disc to disc but it's all the same:
http://pg.photos.yahoo.com/ph/tarami...er72/my_photos
You're looking at $150 or so: $65 prop, $50 master, $40/pr cables (need 2).
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
armybyrd
Aug 10, 2015 09:23 PM
