Wheels and Tire pics
Anyone have any pics or experience with a 15x8.5, 4.875" BS wheel and 295/50-15 tires? The wheels are centerline autodrags. I was told they were 5.5", when I looked them up turns out their 4.875" and haven't purchased the tires yet, Trying to avoid the sticking out look. At the lip or tucked in is what I'm after
Any input appreciated
-Jim
-Jim
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Probably won't stick out, but you'll have to cut up the bump stops and probably beat the crap out of the inner wheel wells.
I had 275/50/16 Hoosier Quicktimes [26" tire] on 15x9 Draglites with 5" BS and had to cut up the bumpstops and use an adjustable panhard bar to center the rear end. You might have to do the beating because you're a little bit taller and a bit wider so you'll have more sidewall bulge.
That actually looks a lot better then expected… you mind posting a few more pics from different angles/both sides?
From that pic it looks like you could use some spacers to space the front wheels out a little…
No problem, just got into work so I'll post the others I have when I get home. And I like the fronts tucked in like that, looks like the Quick 8 cars around here.
-Jim
-Jim
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Originally posted by conlinj
I need to adjust the panhard bar to center the rear back up, it's over to the left a little more, the pass side is half an inch in more
Originally posted by Stephen 87 IROC
Try finding a third gen that isn't like that. It's just more noticable with wide tires.
LT1Formula
Nov 16, 2015 01:13 PM
