Suspension Ideas For 86 Trans Am??
Old Jul 23, 2005 | 12:37 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
can anyone help me with suspension for my vehicle, as you can see in the pic, i would like to level it off or lower both, but all in all id like the front either level or slightly lower then the back
Old Jul 23, 2005 | 02:12 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Good looking car, but man that thing is sitting High! is there an engine under that ram air hood? What size are the wheels and tires?
It definatly needs a good lowering, there are many options to go. Most here seem to like Eibachs sportlines or the Pro kit. Try a quick search.
Old Jul 23, 2005 | 05:51 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah there is a motor under it, a 350, actually with estimate 400HP.. this is how the car came, the rims are 17x8, the front tires are 225/45/17 and the rear are 245/45/17.
id like to change the struts, springs, and shocks, is it necessary? or just the springs?
Old Jul 23, 2005 | 06:16 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i looked around, but any ideas what would be the best, and what i could get away with? like 3" drop? 2"? 1.75"? 1"?
id like to know since im guessing many people have done this.
thank you
Old Jul 23, 2005 | 06:52 PM
l98-tpi-guy's Avatar
Car: 1989 IROC-Z
Engine: 5.7L TPI
If you have the money, do the shocks and struts. If your current setup is in good shape you can get away with doing just the springs(Eibach Pro-Kit). If you go with the Eibach Sportlines definitely get some new shocks/struts.
Old Jul 23, 2005 | 07:00 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok thats brings me to another question. im not sure if im saying it right.
but do you notice how the front end sits up higher, does that mean im gonna have to get a lower spring in the front then in the back, or when i take out the old ones they will be level?
does that make sense?
Old Jul 24, 2005 | 10:43 AM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Where in the TO do you live. I have to come check that car out one day. It is just sick.
Old Jul 24, 2005 | 11:50 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i live right Downtown on Bay Street.
Old Jul 25, 2005 | 04:56 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
If you buy one of the Eibach kits, it comes with 4 lowering springs. If they are indexed correctly it should end up sitting level.
Old Jul 25, 2005 | 05:48 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok but do you know what i mean? the front sits quite a bit higher, if the springs are all 1" lowering or 2" lowering, would that still make the front sit higher?
Old Jul 25, 2005 | 09:19 PM
Car: 1989 IROC-Z
Engine: 5.7L TPI
If you are planning on doing the job yourself, checkout the insulators on top of the coil. If the car had any suspension work done, someone may have replaced them with some thick insulators. They will add some height to the front end. With Eibachs and the thin insulators your should get a nice drop and it should sit level.
customblackbird
Aug 15, 2021 10:16 PM
camaro11j
Sep 19, 2018 08:49 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
