lower ball joints are worn..../sfc's
Old Aug 3, 2005 | 04:20 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Anyone know any good/cheap shops in So Cali that will do this?
also, i was looking into sfc's... what is the difference (if any) between weld and bolt on? (daily driver, not a track car) also, what is thier primary benefit?
Thanks for the help
-Tim-
Old Aug 3, 2005 | 05:11 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Primary benefit is to cut down, if not almost eliminate the flexing of the body. It also provides convenient jacking points too
I would suspect that bolt-ons would still be able to move (very slightly) becuase they're bolted and not welded, however some people have welded them after bolting them on.
Mark.
Old Aug 3, 2005 | 12:19 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
get them welded in, over time the bolt in variety will stretch out the holes and cause flex
Antips16
Oct 30, 2015 06:42 PM
jbates346
Oct 21, 2015 01:50 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
bubbaz28
Sep 18, 2015 02:09 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
