Sounds like loose change..
Old Aug 4, 2005 | 09:44 AM
98form's Avatar
Car: 87 IROC G92
Engine: LB9
Axle/Gears: BW 3.45
Hey guys. I have a suspension problem. Everytime I hit a bump or pothole or anything like that, I hear a sound coming from the front suspension, most likely the passenger side, that sounds like someone jingling some loose change. Does anybody know what this could be? I am pretty sure it is in the suspension somewhere. What could be loose that would make that noise? Thanks in advance for any help.
Old Aug 4, 2005 | 10:20 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Check your swaybar endlinks.
Old Aug 4, 2005 | 11:30 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
I had the same problem. I replaced the endlinks. still there. recently I replaces every single piece of the front suspension + steering linkage. still there. I swore up and down it was comming from the right front end. well, turns out it was coming from my right side......... it was the e-brake handle jingling. The whole time the problem was right under my nose. just goes to show you how perception isn't always as it seems.
Old Aug 4, 2005 | 11:51 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
thats a good point... I have a similar problem that I swore was coming from the rear. I checked, rechecked, and replaced everything... Turns out one of the bolts were loose on my trans crossmember!
Old Aug 4, 2005 | 02:40 PM
98form's Avatar
Car: 87 IROC G92
Engine: LB9
Axle/Gears: BW 3.45
Ok, thanks for the starting points. I'll take a look and see if I can spot anything in those areas that may be loose.
Old Aug 5, 2005 | 12:10 AM
83 Crossfire TA's Avatar
Try running a magnet around the inside of the K-member… I was once working on a friend’s car that was doing something like that and it had half a dozen nuts and bolts inside the bottom of the K-member.
Old Jul 27, 2019 | 01:20 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
Re: Sounds like loose change..
Resurrecting an old thread. The k-member idea is a great one. I have the same chain dragging / loose change issue. My endlinks WERE shot and doing all the bushings helped but it was still there just nowhere as bad. Other loose items: rear hatch pulldown had a loose bolt, the interior bolt for the rear seat striker was loose, I had loose bolts for one of the t-top bag mounts to the rear clip. Basically, anything that isn't tight can cause it.
Old Jul 28, 2019 | 06:01 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
My god
FormulasOnly
Jul 23, 2018 08:47 AM
92firebirdguy
Sep 1, 2016 07:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
tmellott89
Oct 14, 2015 02:06 PM
wanext
Oct 6, 2015 12:18 AM
