Question about centerlink replacement
Old Aug 5, 2005 | 05:04 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i called up a shop and asked them about getting a front end rebuild inner and outer tie rods, idler arm, balljoints and alignment. i asked about the centerlink and he told me its a non wear item and shouldn't bother replacing it unless its bent.
is it an item i should replace or not bother with?
Old Aug 5, 2005 | 05:15 PM
Stevo's Avatar
Car: Pair of 92 Z28s
i replaced mine because it was bent
i beilive the guy is telling you the truth.
Old Aug 5, 2005 | 05:25 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yeah this is a pretty reputable shop, they've done work for me before so i kinda believed him
Old Aug 5, 2005 | 10:25 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
The center link IS a wear item, it has joints where it attaches to the pitman and idler arm, the only non-wear item in the steering on a 3rd gen is the pitman arm.
Old Aug 5, 2005 | 10:46 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
x2 just replaced my whole front end, only piece i retained was the pitman.
Old Aug 6, 2005 | 01:18 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Yup, he's thinking about ford style parallelogram front linkages, where the centerlink is non wear and the pitman is a wear (pitman is the only non-wear steering linkage part on a 3rdgen) and the idler has an extra wear joint.
Replace it, a lot of wear actually build up there.
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
