Spohns new boxed lca's
Old Aug 18, 2005 | 11:10 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
stronger or weaker then the tubular ones?
better for daily driving?
Old Aug 19, 2005 | 07:47 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
The stock A-arms (front) are better for daily driving. His rear LCA's are better than stock.
Old Aug 19, 2005 | 07:54 AM
CaysE's Avatar
The question is whether or not the Spohn Boxed LCAs are stronger than the Spohn Tubular LCAs.
I imagine the boxed ones are stronger due to their size, but should only be used on stock height cars. Lowered cars should use the adjustables for good alignment.
Old Aug 19, 2005 | 08:23 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
When did Spohn release boxed LCA's? He hasn't sent a "New Products" newsletter to his mailing list yet.
Did he start a thread on this forum that I somehow missed?
Adding a boxed LCA to his product line seems like a redundency.
Old Aug 19, 2005 | 08:34 AM
CaysE's Avatar
I agree I'm kinda questioning why he came out with them, it's kinda like saturating your own market. But they're on his website.
http://www.spohn.net/product.cfm?productid=1552
Old Aug 19, 2005 | 12:48 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Sorry! I didn't realize he had a new product. I would wager that the boxed versions are stronger than the tubular versions. As far as which one for a daily driver? I think they would both be about the same.
Old Aug 19, 2005 | 06:10 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well i'm leaving my car at stock height, but i'm wanting the strongest aftermarket lower control arm i can find, i was gonna get his tubular ones in chromeoly, but the boxed ones seem to look beefier and more able to handles the stresses of daily driving
Old Aug 19, 2005 | 06:23 PM
laiky's Avatar
I would get the boxed ones if i was dragracing, they are heavier but probably stiffer than the tubes. Only really good for strait line and a lot of traction though (IMHO). I still don't like the poly bushed aftermarket arms because i feel they will increase binding over the twisty stock arms and poly bushings
Old Aug 19, 2005 | 07:43 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
the binding issue i was going to adress, by going with a rubber bushing on one end and a poly on the other
Old Aug 20, 2005 | 05:03 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
thats what i have on my car and it's my daily driver. No prob in 2 years. i would say they both have good and bad on them. I would get the ones i have if you plan on any suspension upgrades though. my 2 cents
Old Aug 21, 2005 | 02:18 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
this car is going completely under the knife as far as suspension goes, spohn panhard bar adjustable, lca's, torque arm, 3pt stb, new springs and struts, new a arm bushings, upper strut mounts, poly endlinks and greaseable swaybar brackets with poly bushings
already has new shocks, wonderbar, sfc's, moog rebuilt front end
this car is getting auto crossed
$750 L98
Feb 1, 2025 02:25 PM
MrPackstin
Oct 25, 2017 08:09 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
