Weights of rear LCAs?
Old Aug 23, 2005 | 11:34 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Anyone know the weights of aftermarket rear lcas? I'm in the market for a set. I'm most likely going with lakewoods because they're 90 bucks. Does anyone make a chrome moly LCA?
Old Aug 23, 2005 | 11:36 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
spohn does IIRC. they are way more than 80 bucks though.
Old Aug 24, 2005 | 01:09 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
BMR sells chrome-moly versions too, http://www.bmrfabrication.com/F3-suspension.htm. The price ranges from $160 to $250 a set.
I can not help you on the weight of aftermarket LCA's. I would recommend contacting the manufacturer.
Old Aug 24, 2005 | 02:24 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
BMR-------------------------Single----- Total
stock lower control arm------4.7#------10.4
standard tubular lower-------4.4#------8.8
chrome moly-----------------3.4#------6.8
boxed----------------------7.2#------14.4
Spohn
Part # 201: 6.90/pr------13.8-----------Tubular with Poly Bushings
Part # 202: 11.00/pr------22--------Boxed with Poly Bushings
Part # 203: 7.70/pr.------15.4------Adj. with Poly Bushings
Part # 204: 8.90/pr.------17.6------Adj. Spherical/Poly Combo
Part # 206: 7.95/pr.------15.9------Adj. Spherical Rod Ended
Old Aug 24, 2005 | 05:40 PM
Jade Grey's Avatar
Engine: 305TPI
Are the Spohn LCA weights you listed for the chrome-moly versions?
Old Aug 25, 2005 | 12:30 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Edit-- I don't know, I'll find out.
I remeber reading that poly bushings on the frame wouldn't be good because it could flex part of it. Anyone have a link to that post?
If that's the case, BMR has poly/rubber combos.
Old Aug 25, 2005 | 12:32 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
they make cm lcas/ its an option mild steel or cm
Old Aug 25, 2005 | 04:54 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
No thats for MS... the 4130 stuff weighs within an ounce of that list. Since it is 1.25x.095 same as the MS..
Kat
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
