wonder bar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can pre-load the front end with one to achieve a desired set-up. If you are not an all out racer where minute adjustments are necessary than stick with a non adjustable unit.
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
according to spohn their wonderbar wont fit an '82. anyone know why?
I dont think an adjustable will make much differance.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
part way through '82 the bolt holes changed.
The TDS wonderbar claims to fit all years, due to a swiss cheese looking mounting tab.
I'm making my own for my '82.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Given the chance, I'd buy the TDS again if I couldn't find a stock one again.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
before hunting junkyards for a stock one keep in mind that the TDS wonderbar has three mounting bolts instead of just two
darwinprice
17
Oct 11, 2015 11:51 PM
