Noise
Old Sep 22, 2005 | 08:52 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Noise
Can the steering linkage make hmmm like a bending twisting or whatever you want to call it sound ... when one hits the brake hard ?
This only happens when I stop at stop signs and floor the brakes
Old Sep 22, 2005 | 09:49 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Thats the all to common thirdgen pop. It could be alot of thengs just start going through the suspension.
Old Sep 22, 2005 | 10:36 PM
Stevo's Avatar
Car: Pair of 92 Z28s
my car does this and kind of a small clunking noises when coming to a stop hard on the brakes...i got no clue what it could be...thought maybe a rear end problem i dunno.
Old Sep 23, 2005 | 02:58 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Well, I'm too lazy to try and find the link to the post, but... There's a post here about fixing the popping sound. It essentially involves removing both front tires and checking underneath the bottom control arm on each side for 2 or 3 loose or missing bolts. A large number of people checked and found the bolts missing or very loose. Tightening/replacing them usually fixed the noise. Even if this is NOT your problem, you might want to check all those bolts and make sure they are there and tight. Also check the transmissions crossmember bolts. Some reported missing bolts there as well. As long as you're under the car, check for the frame rail crack near the steering box.
Now if it's the tie rods/other connected linkage making this noise, I can only say you should get it replaced immediately if the joints/connecting ends are loose in their housings. I had a centerlink that was about as loose as a 50 ce... nevermind, you get the idea. The steering was so sloppy it was basically an adventure unto itself keeping the car straight on the road. The steering wheel had an ungodly amount of play, and I don't mean an inch or two.
Old Sep 23, 2005 | 05:22 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmm
We're talking about the X-member bolts ?
Old Sep 23, 2005 | 05:37 PM
Elthesh's Avatar
Here, check this thread.
https://www.thirdgen.org/techbb2/sho...hreadid=237871
There are 2 pictures. One of the control arms bolts, the other of the transmission crossmember. Find both of them and match them up to your car and check the bolts.
Old Sep 23, 2005 | 09:00 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
ok
That's the topic I thought ya meant yeah ... I may have stripped threads though
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
