3rd or 4th gen swaybar?
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
just finshed up my 9 bolt to ls1 rear end swap but i noticed that my stock 9 bolt swaybar is way bigger then the 4th gen one what do you think?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
4th gen suspensions have a slightly different suspension setup so, they don't require as large of sway bars.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Looks the same to me.
Axle/Gears: 3.45, 3.27, 3.27
Originally posted by Zepher
What is different about the 4th gen rear suspension setup?
Lon
Originally posted by lonsal
The rear suspension is the same. However you're trying to balance the sway bar with the front suspension which IS different on tht two cars.
Lon
Lon
He's had it on there since he took my rear end a couple of years ago.
1992rs/ss
16
Jan 28, 2016 09:58 PM
