Subframe Connectors... TDS or Spohn?
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
The first modification I'm shooting for on my 91 GTA is probabably going to be subframe connectors. My car squeaks just a little bit, so I'd like to tighten up my frame before I get any cracking. The only 2 manufacturers/distributors I found were Spohn and TDS. Which product is better?
Thanks for the help,
Bill
P.S. while I'm add it, any other nifty suspension/frame mods I can do? I was thinking of the TDS or Spohn wonderbar as well. (Who's got the better prodcut?)
Bill
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have both the Alstons from TDS and the Spohns and I prefer Spohn, they're longer and will give more backbone to the car. INstall was not too bad either.
Ed
Ed
Thanks for the fast response Ed. Another quick question... Can anyone reccomend a good shop in NJ to install the kit for me? I'd also like my frame realigned to compensate for any sagging that has taken place.
Bill
Bill
p.s. Is it worth it to pay the extra $45 for paint, or should I pay a body shop to paint the subframe connectors?
Car: '87 FIREGOOSE!!!!
Ed, can you install BOTH Alstons, and a "perimeter" style like Spohns (they are that style aren't they?) or Kenny Brown togeather? Or is there clearence problems? I was thinking of the MOST possible stiffening. Why not install both styles?
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Might not matter on a street car, but with both of those SFCs combined, you're probably looking at 50-60lbs of added weight.
In a race situation, it makes more sense to add a cage then two sets of SFCs.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Originally posted by nape
Weight.
Weight.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Alston vs Spohn sfc
On my T-top 88 I too wanted to maximize strength not caring about weight as it is strictly for the street. So I used both the Alston & Steve's SFC's and then tied the passenger side together behind the cat and am very satified with the result, very few squeaks now. I have the GM wonder bar and a STC which helps also. I think T-top cars need all the help we can give them. Dave
What is an STC?
If adding 2 sets of SFC's is the best for my car, than I'll do it. But, is it really worth it? I would like to race my car, so I dont want to add a TON of weight. (I have a hardtop btw) But, if adding 2 sets of SFCs will drastically improve the rigity of my car (as opposed to only one set), then I'll do it.
Any comments?
Also, does everyone agree that spohn's SFCs are better than Alston's (TDS's) SFCs?
JamesC, thanks for the link. What does everyone think of global west's SFCs?
http://www.globalwestsuspension.com/...OVMTC=standard
Any comments?
I do not have both on the same car although Spohn and Alston will fit and can be installed together. I have the Spohns on one car and Alston on the other. Both are good but Spohn are longer and attach in more places and therefore make the one car stiffer than the other.
Ed
Ed
I agree with Ed, Spohn's sfc are better. I should have posted that I installed Alston sfc's first, then added the sfc from Spohn and could tell the difference. I believe that the longer pieces from Spohn will do better, However everyone may have different experiences than I have. Both sets are probably overkill.
Redbird, you had both sets of SFCs on the same car?
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
stc
I,m curious too what is this "STC"
Wgripp, Yes , I have both sets on the same car. I installed the Alston sfc first and still wanted less twisting so went with Spohn's connectors which I believe suit our cars better as Ed said they are longer and fit the along the outer rail and in my opinion providing better support. If I had to do it over, I would buy only Steve's connectors. But my car seems very good to me.
W1964bgta, I too, am curious. What is this STC???? My bad. I meant STB.
It is a sure sign of old age. Dave
Re: stc
Originally posted by Ziggster
anyone have pics of Spohns SFC installed?
https://www.thirdgen.org/techbb2/sho...=spohn+install
Ed
Ed, can you install BOTH Alstons, and a "perimeter" style like Spohns (they are that style aren't they?) or Kenny Brown togeather? Or is there clearence problems? ......
If you were only going to install one set, or could not/would not get a custom exhaust system then go for the Spohn SFC's.
I want to get exhaust for my car. Are you saying that the Spohn system will get in the way? Or will TDS's Alstons get in the way?
Bill
Bill
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
one thing to think about, spohn's t56 crossmeber/torque arm setup will not cleat the alstons without cutting a chunk off both sides of the crossmember. i just found this out trying to install mine. not a big deal, but for people who do not have access to plasma cutters and the sort, it might make them think twice about installing the alsons. they are both great produts, but do not have the bolt on compatabillity when used together.
thanks
thanks
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
For a wonder bar, definitely go with the TDS unit. Doesn't require any modifying, whereas the Spohn piece usually requires the fan shroud be cut up a little bit.
I have the Spohn SFCs in my garage, still need to be installed. There was only one other brand I'd consider because they also had a cage that tied in with their SFCs. Forgot the brand though
Redbird87 thanks for clearing that up for I thought I had found the holly grail of suspension parts LOL
got the t56 crossmember/tq arm setup installed tonight. i had to cut around 4 in length off the section that would occupy the same space as the alstons. the plasma cutter made quick work of it and now it fits like a glove.
thanks
thanks
Car: 1991 GTA
Engine: SuperRam 350
How about these two? The Kenny Browns have some additional parts or something? They are more expensive too. Would it be wise to spend the extra money on the KBs?
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
The Spohn ones you posted are for the 4th gens.
Here are the ones that you want.
http://www.spohn.net/category.cfm?categoryid=1052
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Originally posted by Firebreather
[B]How about these two? The Kenny Browns have some additional parts or something? They are more expensive too. Would it be wise to spend the extra money on the KBs?
Oh, and you can find the KBs for cheaper than $279 if you look hard enough.
Car: 1991 GTA
I'll have to look somewhere else anyway. The guys at Thunder Racing charge $500 for s&h for my order so I'll go somewhere else where I would get charged under $200 for the same order.
Engine: Cammed 6.0L LSX
so if i'm looking at getting a Eibach pro-kit springs set and putting that on, should i also look into a set of Spohn sfc's? how much change am i going to feel on the road with both installed?
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Originally posted by soulbounder
I think KB's are the best SFCs on the market. They are boxed where it matters and tubular on the small braces going towards the transmission. The ends of the rails extend all the way back to the rear LCA mounts and secures there. I hear they are pretty light as well. If it were my car, I would spend the extra money.
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
darwinprice
17
Oct 11, 2015 11:51 PM
tmork454
Sep 29, 2015 06:33 PM
