question on replacing swaybar endlinks...
Old Nov 5, 2005 | 10:40 AM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
i can see the front ones very clearly but my question is can i replace the front and back ones without having to jack up the car and/or taking the tires off?...
Old Nov 5, 2005 | 11:02 AM
LT1guy's Avatar
Car: 1987 Trans Am
Re: question on replacing swaybar endlinks...
Doubtful, unless you are really skinny with very small arms...in the rear esp.
Old Nov 5, 2005 | 11:04 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
make it easy on yourself..at least get a good jack man.
Old Nov 5, 2005 | 11:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Get a lousy jack, and a pair of JACK STANDS.
Old Nov 5, 2005 | 08:00 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Another tip if the old ones are realy rusty just cut them off with cut off wheel or sawzal. Better then fighting rusty bolts.
Old Nov 5, 2005 | 11:54 PM
Trah84Z's Avatar
Engine: 305 V8
would a two ton jack and a pair of two ton jack stands be efficient...
Old Nov 5, 2005 | 11:57 PM
Trah84Z's Avatar
Engine: 305 V8
and another question...CaysE recommended these for the front and back...
http://spohn.net/product.cfm?productid=1351
all i do is just put them on right...there's no special calibration i need or anything...just tighten them up?...
Old Nov 6, 2005 | 01:38 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Calibration required? No. Torquing the nuts to the correct torque, yes. The torque for the end link bolts is 16-ft-llbs (22 N-M). Also I'd suggest using the special grease on them.
Lon
Old Nov 6, 2005 | 03:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Should be.
Just don't get under the car, without it being supported by jack stands. Don't trust a jack to hold it up, with you under it.
Old Nov 6, 2005 | 04:08 PM
LT1guy's Avatar
Car: 1987 Trans Am
I'm far less trusting of floor jacks than I used to be, since almost all of them are made in China now and the quality control sucks. Always use jackstands.
Orr89RocZ
Apr 25, 2016 08:28 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
