holy *** I need help guys
Old Nov 13, 2005 | 09:58 PM
havoxRS's Avatar
Car: 88,GTA Trans am L98 350tpi
Engine: Edel tes headers,airfoil,Hypertec chip,AFPR,K'N filter,Intrax springs
Transmission: 700r4 Auto ,B&M stall converter , B&M shift kit ,Vette cervo,Alu Driveshaft
k i was getting ready to install my headers and i happen to run apon my steering box and a ****ing huge hole in my frame it is the worst ive seen on a thirdgen ,i need help ill post some pics i know its not weldable because theres a hole
i thought there was a problem but i never looked into it ive only had the gta about 3 months, when im driving it has a popping sound from the drivers front but the car is lowered so i just thought it was a bad strut untill i saw this ,,,
Old Nov 13, 2005 | 09:59 PM
havoxRS's Avatar
havoxRS's Avatar
3 this is the bolt were it bolts to the car it has ripped the metal in
guys i need help anyone please i dont know what to do people say weld it well its a huge hole so no or use a peace of 1/8 metal witch i have and a welder but i heard that ****s up the alighnment of stuff
Old Nov 13, 2005 | 10:23 PM
sellmanb's Avatar
Car: '86 Berlinetta
nothing a welder cant fix
Old Nov 13, 2005 | 10:27 PM
havoxRS's Avatar
ya i knwo and i have one and some metal but how would i go about fixing it because its so big of a hole do i just slap a peace over it and weld it or what
Old Nov 13, 2005 | 11:01 PM
sellmanb's Avatar
Car: '86 Berlinetta
https://www.thirdgen.org/techbb2/sho...hreadid=317091
patch it up to the best of your ability.
Old Nov 14, 2005 | 04:56 PM
Zedsled's Avatar
Car: 84 Z28
Engine: Modded 350ci.
Fixing that hole wont be a problem(i'm a lisenced welder)..You can go about it two ways that would work...
1: get a peice of say 1/8th steel(rectangluar) shape with a 90 degree bend..lay it over the frame where the hole is and have it seal(whole way around) welded to the frame.
or
2: get that hole cut to a square shape(big enough to remove all rotted metal) and get a new square peice of the same size welded in it's place..Put a small bevel or leave an open root(1/16th or so) to ensure full penetration of the weld.
Old Nov 14, 2005 | 06:23 PM
havoxRS's Avatar
thanks man i just saw how big the hole was and how much **** i was going to have to remove and i got alittle scared
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
