Solid engine mounts.
Old Nov 16, 2005 | 01:15 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Sorry not sure where to put this. What are the downside to running solid engine and transmission mounts in your car? Besides the vibrations.
Old Nov 16, 2005 | 02:47 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
If the car twists it is very possible to break the case on the transmission. This is usually fixed by running solid motor mounts with a poly trans mount.
Old Nov 16, 2005 | 07:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I would never recommend the solid tranny mount. Too easy to break the tranny case. I run a front motor plate and still use a poly tranny mount. I'm still debating on putting in a rear motor plate. There's not a lot of room to work with. I'm considering the rear motor plate because if I break the transmission, there's nothing else holding the back of the engine up. With solid motor mounts in the stock location, the engine will still stay in place athough it will tip back slightly even if you take the tranny right off. With rubber of poly mounts, it will tip back a lot.
Solid motor mounts are recommended to keep the engine from rocking around from the torque. Poor man's fix using rubber or poly mounts is to chain the engine down but this isn't a great fix. Some vibration will probably be noticed in the frame but not as much as you would think.
Old Nov 16, 2005 | 08:24 PM
Creak's Avatar
Car: IROC
Engine: 5.0L
Transmission: 5-Spd
If you are going to run solid motor mounts stick with a Poly trans mount.
Old Nov 17, 2005 | 08:48 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Ok cool. Thanks guys.
Old Nov 17, 2005 | 04:09 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I run a solid trans mount. However, I am also using a stock crossmember, which offer some flex. I really have never seen a broken case from the trans mount. You would have to have the wheels in the air and the chassis twisting extremely hard for that to happen.
Reddeath210
Oct 6, 2015 08:20 AM
B_Dubya
Aug 26, 2015 05:09 PM
LittleFranks
Aug 20, 2015 03:55 PM
Street Lethal
Aug 13, 2015 08:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
