how to get c5 wheels to fit?
Old Nov 25, 2005 | 01:22 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
I am going to buy c5 18 and 17 offset wheels. The fronts are 8.5 and the rears are 9.5. I am not really worried about the rears fitting but worried about the fronts. I know i am going to need spacers also. But what tire should i use to make these not rub? My 16 iroc's rub for some reason and they are only 255's. Well I was thinking 245/45 and 275/45. What do you guys thinks. Ill also have a moser 12 bolt and a full spohn suspension when the k-member comes out in a while so will I have to buy new spacers when that gets that in? It's a stock front suspension 90 rs right now.
Brandon
Old Nov 25, 2005 | 02:53 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The 17" front C5's use a 245/45/17 tire and with a 2" spacer there is no rub at all. Stock rear tire is a 275/40/18.
I've got the Eibach Sportlines on my car as well,
Old Nov 25, 2005 | 12:05 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
is there any difference between those and the newer c5 wheel like this one
http://cgi.ebay.com/ebaymotors/17-PO...17037104QQrdZ1
thanks
Old Nov 25, 2005 | 04:24 PM
Zepher's Avatar
thanks
Just the style I beleive. Sizes and offsets are the same.
Old Nov 25, 2005 | 08:48 PM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
i was looking at those rims too, at least corvette rims from the same company on ebay...
Old Nov 25, 2005 | 11:32 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
i hate the shipping costs and am looking for a place close to los angeles
Old Nov 25, 2005 | 11:47 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Anybody think the 18 9.5's will fit in the front?
Old Nov 26, 2005 | 05:26 AM
Zepher's Avatar
I don't see why not.
I had 18x10.5 and 18x9.5 Z06's on my formula
Old Nov 26, 2005 | 12:37 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Any rub on those? I think I am going to buy 4 18x9.5 with 245/45/18 tires. This would allow me to rotate my tires regularly. that would be nice. Or maybe i'll just buy 275 rears. What do you think is best. probably 275 rears.
Old Nov 26, 2005 | 08:07 PM
Zepher's Avatar
245/45 is too skinny and tall for a 18x9.5" rim. skinniest I'd put on would be 265/35, stock size was 275/35/18 for the 9.5"' wide
Old Nov 26, 2005 | 08:29 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
what size tires were on the 18x10.50s Zepher? im assuming thats with the 2 inch spacers?
Old Nov 26, 2005 | 10:20 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Won't 265's rub? If not i would get 265/40/18 tires on all four. What do you think? Will they rub or should i put 275 on all four? I have 16 irocs on my car with 255 and they rub like hell. I hate that sound more than anything. I want the biggest tires possible without any rubbing, and as it looks right now i am getting the 18 c5 on all four. thanks for the help.
Old Nov 27, 2005 | 05:43 AM
Zepher's Avatar
My 10.5's had 295/35's on them.
I have a 98 LS1 rear on my car, equivelent to 2" spacers.
If you get the perfect spacer for the fronts, the 275 or the 265 won't rub.
A 40 series tire on an 18x9.5 will most likely rub pretty bad on teh front when turning.
I placed my C5 rear 18x9.5" with the 275/40/18 tire next to my 18x10.5" Z06 wheel with the 295/35/18 and the C5 wheel was almost an inch taller.
Old Nov 27, 2005 | 09:31 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
I wish i knew where to get 18x8.5 front wheel. then i'd put a 255/35 tire on it and i am pretty sure that wouldn't rub the front. I know i can go up to 285/40 in the rear with no issue.
That's right isn't it?
Old Nov 27, 2005 | 07:46 PM
Car: 89 Formula
Engine: 5.7 TPI
so is the backspacing and everything the same on those wheels as on a 4th gen F body?
Old Nov 27, 2005 | 11:00 PM
Zepher's Avatar
Not really, they are inset more. with my LS1 rear I had to run 7/16" slip on spacers to clear the front lower subframe on the rear of the car and hammer the inner fenderwell a bit.
Old Nov 28, 2005 | 01:15 AM
Car: 89 Formula
Engine: 5.7 TPI
hmm...ok...looks like i need to do some searching and learn some more...
Old Nov 29, 2005 | 10:28 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
So, I let someone drive my car and they dented my rims. I took my car to a shop to see what could be done and they told me not to look at it. That's when i decided to buy my rims. I bought 4 17x8.5 c5 and I'm waiting on the 2" spacers. I ordered 255/40/17 from cooper. They're isn't going to be any rub right?
Old Nov 29, 2005 | 04:58 PM
Zepher's Avatar
Shouldn't have any rub.
Old Dec 23, 2005 | 02:34 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Dude, those C5 rims fit in the wheelwell perfectly!
a) did you have the 4th gen rear under the car at the time?
b) what was the offset of the rear wheels?
Old Feb 1, 2006 | 03:20 AM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
Transmission: 700r-4
How much are the 4 spacers?
Old Feb 1, 2006 | 10:42 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
I got mine off a ebay site thta cuts them out of 6061 t6 billet aluminum. Thats' what skulte amkes themout of but i only paid 120.
Old Feb 2, 2006 | 09:17 PM
jeremie1028's Avatar
Car: 89 iroc
Engine: 383
hey zephyr, do you know the offset on the split 5 spokes?
Old Feb 3, 2006 | 04:43 PM
Zepher's Avatar
Nope, all I know is that they were offset for a 4th gen Camaro. with my 98+LS1 rear end, they stuck out too much on my car. so I got rid of them, and tires were very expensive. I am going to to stick with 17's.
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
