is my steering box going out??
Old Jan 6, 2006 | 12:37 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my old power steering pump would leak and sometimes the fluid would get pretty low....so i swapped out the pump and it still is really stiff when i first start up the car and move it from left to right....it seems to move left from center but if i go right it sticks the first couple times and then it is alright.....what do you guys think???
if my steering box was going out would it be smarter to replace it with a steering box or find a rack and pinion setup and swap it in.....what would fit???
any help would be greatly appreciated....thanks!
Old Jan 15, 2006 | 06:31 PM
tagta189's Avatar
Actually I am curious about the answer to this also,I have the same problem.I don't have any leaks but my steering is really stiff when cold.And I am not talking 10 degrees cold but 45 degrees outside temp even and it is really stiff till the engine generates some heat.Are we talking steering box here?I have already changed the steering fluid.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bubbaz28
Sep 18, 2015 02:09 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
