mini starter problem!!!!!!!!
Old Jan 8, 2006 | 10:35 AM
noelito1991's Avatar
Car: 1991 gta trans am
Engine: 355
Transmission: TH400
ok guys this happened to me last night and i couldn't figure out if my ministarter was defective or if it was my fault. i recently installed my hooker long tube headers in my 91 gta. i then ordered a csr mini starter. it fit great but when it came time to start the car the pinion wouldn't come far out enough to engage the flywheel..........needless to say i was pissed, do you guys think that this part was defective or something. i put in like 4 shims and it didn't do anything (i know the shimms don't have anything to do with the distance between the starter and the flywheel just had to mention the frustration of putting them in one by one at a time, because i though it wasn't lighning up right)f any ideas or recommendations for a ministarter that will fit with my hooker headers. i was looking at a new msd ministarter, wierd right, but it looked bad *** and msd is a kick *** company. need help guys!!!!!!!!!!!!!!!!!!!
Old Jan 8, 2006 | 01:33 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I have the same starter and headers mine works fine also had the factory starter on the car with the long tubes.
Old Jan 8, 2006 | 02:04 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
The flexplate on the right way?
Old Jan 10, 2006 | 08:01 PM
Engine: 355
Transmission: TH400
what is the distance between the starter pinion and the flywheel?, is it an inch or closer.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
