do i need to upgrade my suspension??
Old Jan 9, 2006 | 01:41 AM
1985firebird's Avatar
Car: 85 bird
Engine: 305 4bbl
Transmission: 700R
i have a 1985 firebird that i have been restoring and i am going to put a 383 in it with about 400 horse maby a little more. is there any major work that i need to do to my chassis so all that power won't tweak my fram. i have T-Tops also. thanks guys.
Old Jan 9, 2006 | 02:09 AM
Asdfga3's Avatar
Car: 1987 IROC-Z
Engine: 5.7L V8
Transmission: TH700R4
Axle/Gears: 3.73 Borg Warner
Big difference between the title of the topic, and your actualy problem. That 383 isn't going to do much to your suspension, but it will wreak havok on your unibody.
Weld-in subframe connectors should just about do it.
Old Jan 9, 2006 | 02:08 PM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
Transmission: 5 speed
sfcs, wonderbar, stb, roll cage
is what i think would be best. If you have ttops you may want to check out these sfcs as well..
click link
https://www.thirdgen.org/techbb2/sho...hreadid=335711
Old Jan 10, 2006 | 11:09 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
With that power, I would redo some of the bushings on the rear end too. Torque arm, panhard bar, lower control arms. I would replace them (I am with the L03) to make the car handle power in turns better. I would at least get some new polyurathane bushings if not replace the rods, bars, and arms themselves.
But that is just my .02.
J-money
Jan 4, 2019 09:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
starfinder
Oct 25, 2015 10:40 AM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
