setting up drag race type rear susp
Old Jan 17, 2006 | 09:21 PM
86t/a owner's Avatar
Car: 86 t/a
Engine: 383 sbc on nitrous
Transmission: Th350 with trans brake
Axle/Gears: 9in ford
Hi
Here is what im needing to find out lol i dont want to go 4link so i want to use a tq bar, what is the best set up for these cars? im pretty much swaping out my race car drive train from my g body to my 86 trans am. needing to no what kind of arms, bushings, just what works on these cars and what does not, ill tell ya alittle bit about the setup.
Im running a all forged 383 with sportman 2 heads and a cold fusion fogger with pills for a 300hp hit, going threw a th350 with a trans brake to a 9in ford rearend with 3.90 gears, i need to get this thing to hook and i only have till april 2nd to get this car done so any help would be great. Thanks guys
Nathan
Old Jan 17, 2006 | 10:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Click on one of the above sponsor banners for www.spohn.net and buy his products. For most people, good aftermarket replacement parts for the factory setup will work fine.
If you want to use a torque arm system, you either need to buy a 9" housing that has the mounts welded on for the torque arm adaptor bracket or purchase the bracket and have the mounts welded onto your own 9" housing. If that's a 9" coming out of your G-body and into an F-body, it won't work. You'd be better off selling the G-body diff and buying one designed to fit into a third gen. I know the suspension is completely different. I'm not sure on the width.
My 9" housing came out of a 1970 F100 truck so I went with a ladder bar system for the easiest installation.
Old Jan 18, 2006 | 12:29 PM
Car: 86 t/a
o i no about the g body rear not working im just going to use my thirdmember, from what i was told i thought that the only way to use a 4link was to tub these cars? If not it might be somethen to look at would it be possable to get some pictures of your rearend set up stephen? Thanks again
Old Jan 18, 2006 | 03:47 PM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
Transmission: 5 speed
suggestion
if you dont have subframe connectors and you have a 383 it would be a good idea to get some to prevent the allready weak and brittle unibody from twisting. Also they will let u utilize your torque so it actually hits the ground.
JMO
Old Jan 18, 2006 | 09:25 PM
Car: 86 t/a
yes im going to pick up some weld in sfc, also putting in a 8pt rollcage. anyone got some pictures that i can look at just want to see. Thanks guys
Nathan
Old Jan 18, 2006 | 09:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
There should be some pics on my web site showing my ladder bar set up.
Since you already have the third member, that's a good chunk of change you don't have to spend. Order a third gen diff housing. It will come with axles. Make sure you know what spline count your carrier has. I'm guessing 31 spline. 28 spline is small and 35 is a bit of an overkill. I'm almost to the level where I need 35 spline but still run 31's. I have Strange axles in my diff. Custom ordered.
The third gen housing with axles should be less than $1000.
Old Jan 19, 2006 | 11:10 AM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
a pic
of umi sfcs. There is more info and pics in the GP area of TGO.
These are weld in sfcs
Old Jan 19, 2006 | 06:03 PM
Shagwell's Avatar
Car: projects.......
I agree on sticking w/ the factory suspension lay-out. Work very well, the factory pieces just aren't up to snuff. - I'm running a factory-style 3-link suspension with home-made sub-frames,boxed LCA's, relocates, and torque arm. My subframes are actually more of an "in floor frame", same concept, just stronger. I'm cutting 1.66 60fts on 17's...
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
