How does your camaro with 18" wheels ride?
Old Jan 30, 2006 | 09:32 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
I'm the process of buying some 18" Z06 rims for my 86 camaro and I wanted know if I could get some feedback from you guys/girls with 18's on you car.
How does it ride?
Do they rub the fenders?
Should I go with 17's in front and 18's in the rear for better ride quality?
Thanks,
Jay
Old Jan 30, 2006 | 10:40 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Come on I know somebody has 18's they can comment on.
Old Jan 30, 2006 | 04:36 PM
Car: 1991 Z28 Vert
Engine: LT1 350
I guess know one has 18" on their car, huh?
Old Jan 30, 2006 | 07:10 PM
CrazyHawaiian's Avatar
Car: too many ...
People do, they just aren't on the forums as often as you apparently hehe. You gotta keep in mind that the suspension setup also plays a huge role into the ride feel of the car. I ran my 18's with sportlines for a while, then went to stiffer linear spring rate setup. The ride difference between the two was drastic. I wouldnt go as far as to say this car rides good, but it sure performs good. I'm sure if you did the same wheels on a stock suspension car it would ride very close to stock suspension feel.
Old Jan 30, 2006 | 07:36 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
I cant really comment on the difference between my 15"s and 18"s because when I swapped the two out, I also redid almost my entire suspension...including SFC's. So the car was noticebly stiffer and you could feel more bumps, however it's nothing my back is going to break over....I like it
Old Jan 31, 2006 | 01:16 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
When I bought my car it had A Pro kit kyb agx's and gas shocks with regular tires on the stock 16" wheel.When I got it home I put on some 18x9"wheels with 265/35/18 tires and it does ride a little rougher but way better on corners!The car handles like it's on rails and it's smooth too.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Linson
Aug 21, 2015 02:12 PM
